Thoughts on why I keep setting a code 33
Old Aug 1, 2010 | 06:42 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
So I have a low miles MAF sensor on my car. I replaced the suspected stock/original unit 5 or 6 years ago and it probably has less than 10K miles on it. I am wondering why I keep setting a code 33. It has set when I go WOT. I have replaced the TPS as it was faulty. Have confirmed correct voltage at terminal C of the MASS AIR CONNECTOR.I am wondering what you guys have seen or run into in the past concerning this fault. I am leaning towards either a bad maf or maybe a wiring issue. Any thoughts would be appreciated. Thanks fellas
Will
Azrael91966669
25
Jun 20, 2017 04:04 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
