can the intake come off in 1 piece?
Old Aug 9, 2010 | 04:29 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
is it possible to remove the tpi system in 1 piece or do i have to take the runners off then everything else? and a little side question can any gen1 intake manifold bolt on and line up with the intake and exhaust ports?
Old Aug 9, 2010 | 04:55 PM
Guest
Guest
Posts: n/a
Re: can the intake come off in 1 piece?
I think some of the base bolts cannot be removed with the runners in place, so no you cant take it off in one piece.
Not sure what you're asking about exhaust ports, but the locations of the bolts on a SBC pretty much never changed. The 87-up heads have the center 4 bolts at a different angle but thats something you can work around.
Old Aug 9, 2010 | 04:59 PM
Stephen's Avatar
Car: 87 GTA
As far as putting another intake on a TPI.....There are 2 different TPI.
82-86 & 87+. The early TPIs on a standard head with the perimeter bolt valve covers. In 87, they went to the center bolt valve covers. When they switched, so did the intake bolts. 87+ can go on older blocks, just like doing the LT1 intake conversion....It can be done.
Old Aug 9, 2010 | 05:18 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
so i have to take the runners off, ok thanks and so i cant order just any carb intake manifold form summit?
Old Aug 9, 2010 | 05:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Any non-Vortec carb manifold will work. Just make sure you get the right center bolt angle.
Old Aug 9, 2010 | 07:32 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
Ok cool do u know what the center bolt angle is for the intake manifold?
Old Aug 9, 2010 | 07:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Depends what year the heads are.
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
1985chevydude
Aug 20, 2015 12:29 AM
Street Lethal
Aug 12, 2015 11:33 AM
