bad fuel pump...
Old Aug 10, 2010 | 10:04 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
bad fuel pump...
hey everyone... how can you tell if your fuel pump is going bad.. within the past two days my car is really hard to start and it will stall out and die...... when i have the car running i have the fuel pressure cap off and its just slowly pouring out gas... i thought it was suppose to spray out because of the pressure... soon as i turn the car off i press down on the fuel rail valve and i get no fuel comming out at all.... i have a brand new 355 tpi engine with new 24lb injectors and crane afpr but i still have the stock 22 year old fuel pump... also i noticed that i see what it looks like fuel stains or something in the throttle body and plenum...... what is going on.... im thinking its the fuel pump... im kinda afraid to drive it.. any tips would help... thanks...
Old Aug 12, 2010 | 06:17 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: bad fuel pump...
Seems that your pump is bad.Get a fuel pressure gauge,and measure pressure.Should be ~45psi when vacuum line removed from regulator,and engine running.
When my walbro F20000169 pump went bad few weeks ago,pressure drops from 47psi to ~15psi,and below that pressure engine wont run.Now there is Walbro GSS340M and it runs fine.
Old Aug 12, 2010 | 04:19 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Change the fuel filter first - it may be plugged.
Old Aug 13, 2010 | 02:51 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
[QUOTE=88fastgta;4638074]also i noticed that i see what it looks like fuel stains or something in the throttle body and plenum...... what is going on.... QUOTE]
If there are fuel stains in the plenum your regulator may be leaking by, pull the hose off the reg to make sure there is no fuel spilling out of the nipple
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
