Complete EFI TPI setup Painless harness
Old Aug 17, 2010 | 11:01 PM
turboaz's Avatar
I have a complete Tuned Port Injection system for a Small block Chevy in Great shape. Was in a running truck that was retrofitted. Painless harness (all labeled) (3) wire hookup. Includes Manifold, runners, throttle body,all 8 injectors upper plenum, T-stat neck, ecm, Mass air sensor, intake tubes and cone filter,esc module, Billet aluminum small cap distributor. All you need is a high pressure fuel pump and an O2 sensor in your exhaust. Great for any Small block conversion, Fits pre- 87 engines. 265-400. $600 Paul 480-221-9572
Old Aug 18, 2010 | 02:09 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Complete EFI TPI setup Painless harness
https://www.thirdgen.org/forums/engi...pension-parts/
Old Aug 18, 2010 | 07:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Should be in PARTS FOR SALE dept
Terrell351
Jun 13, 2021 01:13 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
L98GTA87
Aug 11, 2015 06:55 PM
squiggy2
Aug 9, 2015 09:30 PM
