replacing a fuel pressure regulator
Old Aug 30, 2010 | 12:07 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
when i replace my fpr, do i pull it from the rubber thing and screw down the new with the 6 screws? when i tried to remove it, it would nt come lose from diaphram i think it is... its a orange flexible rubber peice between the fpr and bracket on fuel rail..
Old Sep 8, 2010 | 07:55 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: replacing a fuel pressure regulator
yes, that is what you do, but you need to bleed the pressure from the rail first. Most likely, those screws are tamper proof. I ended up having to go to my local Sears to get a tamper proof socket that worked. Most likely the top of the regulator will be seated to the diaphram (the orange flexible piece) from heat over the years. Just pry it with a small screwdriver and it should come off.
Old Sep 8, 2010 | 08:24 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, thnx, ill try it this weekend
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
