383 HSR build
Old Sep 2, 2010 | 07:21 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
383 HSR build
ok guys well i have a 1991 z28 TPI speed density with a built 700r4, hooker shortie headers, bbk underdrive pulleys, and a bbk afpr. i am in the process of getting alot of information on building my 350 TPI to a HSR 383. i wanna built it for Nitrous!!!..i have been recommended a lot of parts by some of the users here in this site so this is wat i have in mind oh and please feel free to recommend me any parts that i would need or anything that would help me do my build....
i am thinking of going with this eagle 383 setup from summit
http://www.summitracing.com/parts/ESP-B12111030/
HSR & fuel rail... http://www.summitracing.com/parts/WND-7540/
a 255 walbro fuel pump, some 30 or 36# injectors(still not sure)
a wideband o2 sensor(if someone can recommend me one with a link would help) a kirban performance afpr http://www.kirbanperformance.com/pro...R+%236547.html
AFR 195cc- 65cc with L98 angle plug and the 8019 valve spring upgrade
xr288hr with 110 or 112 LSA and probly 1.6 rockers on the intake and 1.5 on the exhaust (wat do u all think still thinking about wat cam to go with)
some LS7 lifters (maybe some one can recommend me others)
hopefully this month i can start ordering parts in still deciding wat to go wiht or not and i will be posting pics of my parts i get in and also build pics! well feel free to recommend parts or things i should be aware of...thanks in advance
UPDATE*** i have decided that i wanna run a procharger on my car. i still wanna run the 195cc afr's and the HSR..i am deciding that i wanna stay with my bottom end for now since i recently rebuilt it about 16,000miles ago lol..im thinking of running the afr heads with the HSR and just slapping the procharger on there..wat do u all say?!?!?!?!....wat cam and 383 setup would u all recommend me to run some boost on this motor?!?! thanks in advance!
Old Sep 2, 2010 | 08:03 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 383 HSR build
the HSR rails are a rip off... but they are plug and play
I made up my rails with FAST
and converted my Holley AFPR and tapped to except an lines
you should get a 58mm TB the 383 will need it
you diff will need gears.. and I would install C clip eliminators
what about the 700r4 that is going to need serious HELP
Old Sep 2, 2010 | 09:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 383 HSR build
How much?
That will determine if you need a forged crank of not
If you are going to spray on a regular basis you install a NOS cam.Much more exhaust timing to let gases out
http://www.summitracing.com/parts/CCA-08-303-8/
Old Sep 3, 2010 | 12:41 AM
88gta3508's Avatar
Engine: 231 / 383
Re: 383 HSR build
I hope you have selected a 4 bolt main block
or better yet convert your 2 bolt to a 10* splayed 4 bolt
I would look for a better crank like callies and billet steel caps
I would select real forged pistons and rods
especially if your spraying
I have herd Eagle you get what you pay for... China made
the machine work will be around $900.00
I'm in the middle of making a 383
Old Sep 3, 2010 | 03:15 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: 383 HSR build
similar to my build in my sig.the motor can be a handfull and i consider this a mild 383.you can safely spray a 100shot..maybe 150 even stock..just not too often without doing anything except retard the timing a lil.i do wish i went a lil more aggressive on the cam torque wise but my midrange and upper rpm power is very nice..and surprisingly smooth.i working on getting a burnout vid once i fix my tranny but here are some vids of the car to give you an idea of what your in for. just be prepared that with an lsa in the 110-113 range on speed density can be a whoore to tune sometimes but it will give you a lil more power peak.I havent even taken my car too 6000 rpm yet because it is alot of fun..only been to 5200.
http://www.youtube.com/watch?v=CDlg4_KvhN4&NR=1
http://www.youtube.com/watch?v=QMrdqZXk4N4
http://www.youtube.com/watch?v=lFYIKUH2mkg
Old Sep 3, 2010 | 03:54 PM
robg91z's Avatar
Engine: 350ci TPI
Re: 383 HSR build
well i really dnt plan on spraying it all the time..i just want it to hold some nitrous just in case i need it for a crazy race or something..probly would like to shot a 100 shot or 150 shot if i could hold but im going more for a 100 shot..wat do u all think about that cam i wanna go with is it good for this set up i wanna run??
Old Sep 3, 2010 | 04:24 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Re: 383 HSR build
that cam should be fine for what you want to do and will take some spray.110 lsa might not agree with the ecm for tuning..112 will be easier on speed density...other than that
Old Sep 4, 2010 | 01:51 AM
robg91z's Avatar
Engine: 350ci TPI
Re: 383 HSR build
will my stock tpi oil and water pump be useless with this set up i wish to do?
Old Sep 4, 2010 | 11:17 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
Re: 383 HSR build
you can reuse everything if you want.some might say to use the stock oil pump but change to a high volume pickuptube etc. the waterpump is your choice..nothing wrong with using stock but if you are worried about overheating and not having adequate cooling of the motor then use a high flow waterpump for added insurance,im still using my stock waterpump without issues but i do plan on changing it soon to a high flow unit because my stock waterpump is very old and crusty looking lol..and the price difference between a new stock unit and a performance unit isnt much at all.
Old Sep 4, 2010 | 12:51 PM
88gta3508's Avatar
Engine: 231 / 383
Re: 383 HSR build
I would not use a old Oil pump or water pump
drop 8lb off the front with a Aluminum High flow water Pump $45.00 ebay
your car with headers, head & cam will get hot!!!! use a high flow water pump
PS install a spring inside the bottom hose or it will collapse the HOSE....
oil pump new build New pump... I like using HV / HP and install a stock spring
Old Sep 5, 2010 | 04:34 PM
robg91z's Avatar
Engine: 350ci TPI
Re: 383 HSR build
will that HSR from summit directly bolt on to my stock L98 heads..im planning on buying the HSR first and testing it out with my stock heads...i pressed on the application and it says for 86 or later model heads? is that right?
Old Sep 5, 2010 | 04:49 PM
88gta3508's Avatar
Engine: 231 / 383
Re: 383 HSR build
your Good to go.. you found the correct style 7540.. yours is a 91
Old Sep 6, 2010 | 10:12 PM
robg91z's Avatar
Engine: 350ci TPI
Re: 383 HSR build
oh ok the HSR should be my first mod before i buy anything else..ill post pics of my HSR and fuel rails when they are here and also post pics when im installing it...where can i buy the fuel lines that i need for the HSR since the stock ones wont fit??...a link would help so i can order everything at once!! thanks in advance
Old Sep 6, 2010 | 11:23 PM
88gta3508's Avatar
Engine: 231 / 383
Re: 383 HSR build
an lines and fittings
do you have a local hydraulic hose & fitting shop
you can use an to metric o ring and retain the factory lines. these fittings are gold !!
or you can flare on a tubing fitting to an
Old Sep 9, 2010 | 11:06 PM
robg91z's Avatar
Engine: 350ci TPI
Re: 383 HSR build
junior419
Apr 7, 2025 11:35 AM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
