350 tpi
Old Sep 4, 2010 | 12:05 AM
jfroh1992's Avatar
Car: 91 RS, 93 k1500
Transmission: T5, NV3500
Axle/Gears: stock
350 tpi
i just picked up a 87 iroc 350 tpi.
i have heard that the tpi setup between 305s and 350s are the same and this causes the 350s to not have as much power as they can.
is this true?
and if it is would bigger injectors fix it?
Old Sep 4, 2010 | 06:08 PM
donaldw's Avatar
Car: 1988 pontiac trans am
Engine: 305 tpi
Axle/Gears: factory
Re: 350 tpi
correct me if im wrong but dont the 305's run 19lb injectors and the 350's run 22lb injectors.
Old Sep 4, 2010 | 06:21 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 350 tpi
Correct on the Injector Difference
also the 350 eprom has much better settings
if you add the normal performance parts Exhaust, Headers, tune, gears
the 350 will produce!!! much better results
Old Sep 4, 2010 | 08:42 PM
jfroh1992's Avatar
Axle/Gears: stock
Re: 350 tpi
i figured there had to be differences but fingured i should find out for sure
Old Sep 4, 2010 | 09:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 tpi
The intake was designed for the 305 so ultimately it is " too " small for all out power on a 350
Dumping more fuel in by putting bigger injectors will do little except hit your wallet
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
