So I need new injectors for my L98. Have some ?'s
Old Sep 11, 2010 | 12:57 AM
Roc THIS's Avatar
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
So 4 of my injectors decided to crap out . I am new to this whole TPI thing being used to carbs so bare with me here. Let me start by giving you the story of what happened with the car .
Couple days ago I put headers on the car . It ran flawlessly before hand but now barley starts . I managed to get the car to stay running where I then gave it the only injector test I could think of . I walked around the motor unplugging one injector at a time . If I unplugged a "good" injector , the motor would fall on its face . If I unplugged a "bad" one , then the way it ran did not change . There for making me come to the conclusion that 4 of my injectors are done . Not sure if this is a legit way I could test it but its all I could think of at the time .
So now that my injectors are bad , which ones should I get ? I want the bosch 3's but I was leaning toward 24lb-ers . Because in the very near future this car will be getting alot of bolt ons. Not boosting, just porting to the intake system , cam , heads , and so on . Should I go with the 24's?
One more thing . When I put the headers on , I completely forgot about disconnecting the battery . The engine hoist chain touched the positive terminal on the alternator and grounded the car out . The ignition was off and it only made contact for a few seconds , but could this effect anything ?
Ant help would be great . I want to contact southbay to pick up a set of injectors asap but wanted to run all this past you guys first . Thanks in advance
Old Sep 11, 2010 | 09:02 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: So I need new injectors for my L98. Have some ?'s
just call Jon at FIC and get some Bosch 3's
check out the videos on their site www.corvetteinjectors.com
Old Sep 11, 2010 | 12:42 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
injectors don't normally go bad like that, at least not 4 all at once.
are the 4 bad ones all on the same side of the motor? if they are, check for power to the injectors on that side. there are 2 injector fuses under the dash and you could have popped one of the fuses.
Old Sep 11, 2010 | 12:58 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Also check the injectors with a meter, all the ohm readings should be close to the others.
Old Sep 11, 2010 | 04:10 PM
Roc THIS's Avatar
Engine: 5.7 TPI
Ah fuses ! I never even thought about that . There are 2 on one side and 2 on the other .
Edit : Checked fuse ( I have only 1 for injectors) and its good .
Now should I go with stock 22's or go with the 24lb set ?
Old Sep 12, 2010 | 01:17 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
just read your OP better.. When the car shorted out and put all that amperage through ground it could have damaged the driver on the ECU. I believe all those injectors fire at once and it has 1 fuse for the injectors. So, it is possible since the ECM is a ground controller that stray voltage with enough amps could have damaged it.. Just a thought. as far as 22 or 24 it depends on the mods. you will need a custom tune for the 24
Old Sep 12, 2010 | 03:30 PM
Roc THIS's Avatar
Engine: 5.7 TPI
I hope it did not damage the ECM but the injectors are original to the car so i think it will not hurt anything to replace them anyways .
Old Sep 12, 2010 | 09:00 PM
Guest
Guest
Posts: n/a
So how do you know they're bad? Just from disconnecting them?
Take off all the connectors, check the resistance of the injectors. Anything below 12 ohms is bad. Its possible you fried the ecm or damaged a ground somewhere, so if they check ok...
24's you'll need to reprogram the chip. Some people run an AFPR and drop the fuel pressure but thats a huge drop to try and fix it. I'd go with the 24's if you can get the chip done cheaply/easily.
Old Sep 12, 2010 | 09:36 PM
Roc THIS's Avatar
Engine: 5.7 TPI
I have never checked the resistance before . Honestly I dont even know how to yet . Guess I will have to figure that out
Old Sep 12, 2010 | 11:05 PM
Guest
Guest
Posts: n/a
There are two terminals in the injector itself, easy to see when you take the connector off. Use a volt/ohm meter and test between the two terminals. Best done warm because some injectors will show as being ok when they're cold but bad when hot. Usually they read about 16 or so.
Old Sep 13, 2010 | 12:08 AM
Roc THIS's Avatar
Engine: 5.7 TPI
Ok I will have to let the car run for a few tomorrow then check again because I just tested them and they all read 16 to 16.1.
Would my ECM possibly being damaged make some injectors work and some not ?
Old Sep 13, 2010 | 12:50 AM
Guest
Guest
Posts: n/a
Not that I know of. There are only four wires, they branch off in pairs of two and then those two are branched off to each bank of injectors.
Old Sep 13, 2010 | 12:55 AM
383tpimachine's Avatar
Car: Corvette
Engine: 383
Axle/Gears: D36 w/ 3.08
easiest way to check if its the injectors or harness is put the working injectors on the non working side. No squirt still and its the ECM
this way you can also see if the 4 "bad" injectors still work
Old Sep 13, 2010 | 01:51 AM
Roc THIS's Avatar
Engine: 5.7 TPI
But the problem with that is there are 2 injectors on each side that dont work.
And the funny thing about this is that my buddy wanted to hear what the exhaust sounded like right off the y pipe before the cat back was not on yet. So I fired it up and it ran perfectly . Few hours later after everything was back on , it could hardly start.
Old Sep 13, 2010 | 10:58 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Maybe you have a plugged cat. I used FIC for injectors. Jon was great. I will use him again. He has to modify the Bosch 3's to get them to work with TPI. Other shops will tell you to start doubling up o rings. He will treat you right. I just went with 22#.
Old Sep 14, 2010 | 12:43 AM
Roc THIS's Avatar
Engine: 5.7 TPI
That cant be it . For the time being I have no cat.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
TheExaminer
Sep 7, 2015 08:34 AM
