Very loud ticking under load.
Old Sep 14, 2010 | 01:59 AM
87350IROC's Avatar
Car: 87' IROC
Guys,
My engine has developed a very loud ticking under load. It can be heard at idle with my head under the hood but gets worse with load. Other than the ticking the engine is running strong. The sound is loud enough that it is easily heard from the drivers seat while driving.
I have checked for exhaust leaks and didn't find any, however I replaced the header donut gaskets anyway.
If I unplug #7 injector while the engine is running the sound goes away.
That would make me think it was the injector, however the sound is so loud that I'm not convinced.
So I bought an automotive stethoscope to do some listening. I found with the engine running the #7 injector sounds different than the other 7. Other than that I couldn't hear anything funny with the engine. I could not seem to specifically locate the ticking.
I'm guessing its the #7 injector that went bad. But could it possible be that bad?
Old Sep 14, 2010 | 11:00 AM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
Re: Very loud ticking under load.
Cracked or warped exhaust manifold?
Old Sep 14, 2010 | 02:57 PM
Twin_Turbo's Avatar
could even be an arcing wire, they can be very loud, much much louder than ticking injectors.
Old Sep 14, 2010 | 03:51 PM
87350IROC's Avatar
Car: 87' IROC
Thing is the ticking goes away as soon as the #7 injector wire is unplugged.
Old Sep 14, 2010 | 03:56 PM
Twin_Turbo's Avatar
I have to admit, I only read the topic title
It could very well be the injector
Old Sep 14, 2010 | 04:18 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
Transmission: 700R4-
Axle/Gears: 3:27/3:73
leave the injector plugged in and pull off the plug wire, if the noise is still there it could be the injector. if the noise is gone it might be a wrist pin noise
Old Sep 14, 2010 | 06:35 PM
Roc THIS's Avatar
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
I have the SAME issue . I just ordered new injectors and should have them in by the weekend . I will post up any info if this resolves my problem .
Old Sep 15, 2010 | 12:09 PM
87350IROC's Avatar
Car: 87' IROC
I ran the engine with the #7 spark plug wire disconnected and the ticking remained. With the spark plug wire disconnected I disconnected the injector wire and the noise went away.
So an overview
-Engine ticks louder than normal at idle and very loud under load.
-Unplugging #7 injector makes noise go away (could be injector ticking or possibly something on the #7 rotating assembly that goes away when cylinder pressure goes away)
-Unplugging #7 spark plug only and the noise remains (suggests injector is the problem not rotating assembly)
-#7 injector sounds different with a stethoscope than the other 7
So I think its the injector that is broke. Typical Camaro, 12,000 mile Ford 24lb injectors broken.
Old Sep 15, 2010 | 12:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Ohm the injector when its hot and see if it reads correctly?
Old Sep 15, 2010 | 01:44 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
try swapping the injector with another cylinder
Old Sep 15, 2010 | 02:04 PM
87350IROC's Avatar
Car: 87' IROC
I checked after I had the motor running a while, probably close to operating temperature, it read 14.9ohm IIRC. I think that is in spec. One of the other injectors read 15.1ohm I think.
Old Sep 15, 2010 | 02:05 PM
87350IROC's Avatar
Car: 87' IROC
Easier said than done on a TPI motor.
If I'm pulling injectors they are getting replaced.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
