91 305 TPI dies randomly
Old Sep 14, 2010 | 12:01 PM
cpenland's Avatar
My '91 305 TPI dies randomly while driving it. After letting it set for 10-20 minutes, it always restarts. Any suggestions on what the problem may be?
Old Sep 14, 2010 | 12:06 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 91 305 TPI dies randomly
Sounds dumb, but check the battery cables. When my brother first bought his 91 camaro (which is the one I now have) we were driving it around town. When we got to a bumpy road the car kept dieing. Turns out a battery cable was loose. My other brother also just had this happen in his truck. He sat on the side of the road for over 3 hours waiting for me to go look at so that in the end I could tighten the clamp up.
Old Sep 14, 2010 | 12:10 PM
cpenland's Avatar
I will double check them...it would be nice if that is all it is but I don't think I am that lucky. Three of the five times it has died on me has been while it was idling at a stop light. I was wondering if it could be the ECM?
Old Sep 14, 2010 | 12:22 PM
built91Z28's Avatar
When it dies, does it cut out clean or does it stumble for a second or two then die?
Old Sep 14, 2010 | 12:26 PM
cpenland's Avatar
It usually happens relatively quickly without any advanced notice. When it did it a couple of days ago, I did notice it cut out once before dieing. It almost seems like something gets hot and once it cools down it is good to go again.
Old Sep 27, 2010 | 04:42 PM
TheJoeY88's Avatar
when it dies do you still have power like radio or lights?
my 92 has been doing this and i noticed that my fuel pump is cutting off randomly, usually after 5 mins or so it will come back on. Im not getting power to the 12v line to the fuel pump relay when this happens
next time it happens if you have power turn you key from off to on and listen to see if your fuel pump primes, mine doesnt
Old Sep 27, 2010 | 05:53 PM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
Sounds like a bad ignition control module
Old Sep 28, 2010 | 11:09 AM
cpenland's Avatar
I was able to find the problem. Basically the entire bottom half of the distributor was bad including the pick up coil. There was a lot of corrosion in the distributor. Its running good now. Thanks for all the suggestions.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
