How hard is it to get a L98 to 350HP
Old Sep 15, 2010 | 07:54 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
What kind of mods need to be done and how expensive is to get the L98 to 350 HP?
Old Sep 15, 2010 | 08:23 PM
InjectorsPlus's Avatar
Former Sponsor
Re: How hard is it to get a L98 to 350HP
Intake, exhaust, cam, roller rockers.
That should get you there.
Old Sep 15, 2010 | 08:25 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
intake...as in intake base?
suggegstions for cam and rockers and intake??
sorry for hijacking but i want info too :bangs on table: lol
Old Sep 15, 2010 | 11:23 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Big Runner Intake Base ie ported Edelbrock or AS&M.
Large Intake Runners ie SLP, AS&M, Edelbrock.
OR Holley Stealth Ram
Injectors around 32 lbs
Camshaft around 218/224* with high lift
Decent Aluminum Heads (take your pick)
About $2500-$3000 for the top end and you can use your own original shortblock (if it's in decent condition)
Headers (shorties are easier)
catback system....
$500
Now ya have to learn how to burn chips!!!!
No one said it was cheap!
Old Sep 15, 2010 | 11:36 PM
Former Sponsor
Well, for simplicity the Miniram is a good intake replacement (we carry them) bolts right up and good for about 35 HP. I like them because they install easy and work.
The base, runners at least, and perhaps the plenum.
There's the HSR, lots of options.
The cam is a personal thing, nothing to suggest but more the mild but less than aggressive. Probably something that hits at 2500-5500. Depends on what the owner wants. I like a little more aggressive than most people. Mine is 240/246 with .602 lift. (it's a 427) I call that easily streetable.
Rockers? Aluminum is going away and many of the Chro-mo ones are popular now. Something like the Comp Pro Mags.
Still say don't need heads....or mild port on the stockers. There's 100s of dollars not needed to be spent.
Old Sep 15, 2010 | 11:55 PM
Guest
Guest
Posts: n/a
At the crank, or the wheels? Two completely different requests. Obviously at the crank, a lot easier and cheaper.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Breazlan
Sep 25, 2015 11:20 AM
Tarizza
Sep 24, 2015 12:57 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
Randomtask2
Sep 7, 2015 05:06 PM
