MAF burnoff relay replacement
Old Sep 20, 2010 | 02:29 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
I hope this is the proper section to ask the following question, if not sorry.
I recently got a code 36 (MAF burnoff relay). I have an all original 89 IROC with the 5.7. The burnoff relay I removed had the number 8162 over 14089936. I searched this topic to great length but did not find a definitive answer regarding whether or not to replace with the same relay number.
I went to my local chevrolet dealership who advised me that 14089936 was the replacement and that there had been no service bulletin update that would indicate that this is not the correct relay.
I did pull the negative battery cable in case this is an intermittent problem but I also purchased the new relay from chevy. BTW the AC DELCO relay has made in china stamped on it... WTF!
Does anyone know if this is the right relay and if not what number should I have replaced it with? Is there anything else I should be checking for?
Old Sep 20, 2010 | 02:52 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: MAF burnoff relay replacement
I believe the oval shaped relays are all the same, the cooling fan also uses the same relay.
Old Sep 20, 2010 | 06:00 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Well, I re-connected the battery, started it up and let it idle until it was around the 220* mark then shut it down. Waited about 10 minutes, fired it up and no code. Fired it up two more times after that with no code, so I guess it was just an intermittent code 36.
The reprint factory manual I bought off Ebay for 35 bucks is becoming invaluable, as Haynes and Chilton do not give near the explanation on stuff like the factory manual.
Now I have a spare relay lying around but I guess it could have been worse, I could have bought a new MAF.
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
Logan Bryant
Aug 27, 2015 11:52 AM
NBrehm
Aug 25, 2015 11:49 PM
Bert87
Aug 23, 2015 03:50 PM
