TPI intake difference?
Old Sep 24, 2010 | 03:44 PM
PontiacMC's Avatar
Car: Trans Ams
I have heard there is a difference in intakes from Corvette, Trans Am, and Camaro... Is there a difference and if so which is the best. Sorry if this is a repost but I didnt find anything on this.
The reason I am asking is I have a chance at a top end off a 85 Corvette and just wondering if it is worth it.
Old Sep 24, 2010 | 04:53 PM
Drew's Avatar
Re: TPI intake difference?
-deleted
Old Sep 24, 2010 | 05:28 PM
InjectorsPlus's Avatar
Former Sponsor
The regulators are in a different position too.
Old Sep 24, 2010 | 06:18 PM
Twin_Turbo's Avatar
and corvettes always had 90deg bolts going to the heads. The dizzy cover on vettes is aluminum too instead of plastic. Stuff was moved for the camaro, TPI was designed for the C4 vette, the dizzy cover fits perfectly in the firewall on those cars.
Old Sep 24, 2010 | 06:30 PM
PontiacMC's Avatar
Car: Trans Ams
thanks that really clears things up for me.
Old Oct 4, 2010 | 07:33 PM
88blackgta's Avatar
Car: 88 GTA Notchback
Engine: 355
Please explain how the position of the regulator is different.
Old Oct 4, 2010 | 08:54 PM
Former Sponsor
OOPS, was thinking LT-1 vs L-98. Brain fart. Anyway, the feed and return lines are different, Corvette goes down passenger side, F-Body to drivers side.
Old Nov 2, 2011 | 01:21 PM
coreys90iroc's Avatar
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
sorry to revive a dead thread BUT a mechanic told me I have a Corvette Intake, so how do you visually know the diffeence? my egr is in the rear under the plenum. is there anyone who had a picture showing the difference?
Old Nov 2, 2011 | 01:58 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The biggest difference, that nobody touched on, is the difference in the intake bolt angles between 84-86 & 87-92. Which means the early Corvette TPI manifolds will not fit the later Corvettes or F-bodies, without extra work.
Perimeter bolt valve cover heads use a difference bolt angle that the center bolt heads. The difference can be overcome, but that are not 100% interchangeable with the extra work done to make the intake manifold to block bolts work.
1992rs/ss
Jan 31, 2025 05:10 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
Jake_92RS
Aug 11, 2015 10:39 AM
