Rough timing
Car: 88 Trans am GTA
Engine: 5.7 TPI 350
Axle/Gears: 3.27 gears, 9 bolt rear
Rough timing
Ok. I reset timing, Top dead center, re adjusted all the rocker arms. Runs horrible at idle!! when you give it gas in idle it revs up fine. If your on the road, and you floor it, it wont give power. running a computer check it says im running lean, but my engine is running rich! I have no power, it barely idles, and the engine is running rough. Is there any answers to this? It's driving me crazy!
