crane 2032 cam horsepower
Subscribe
Oct 2, 2010 | 07:51 PM
dose anyone know what this will give me (have a l98 standard setup tpi)
these are the specs for those who understand them
Brand: Crane Cams
Product Line: Crane CompuCam Camshafts
Part Type: Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-5,500
Intake Duration at 050 inch Lift: 214
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 214 int./220 exh.
Advertised Intake Duration: 270
Advertised Exhaust Duration: 276
Advertised Duration: 270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.452 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465 in.
Valve Lift with Factory Rocker Arm Ratio: 0.452 int./0.465 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: Yes
Grind Number: 2032
CARB EO Number: D-225-22
Reply 0
Oct 3, 2010 | 09:16 AM
Re: crane 2032 cam horsepower
i had that cam in my old bolt on l98 engine.... it made a noticeable difference down low.... also had a nice lope to it.......... i think you would be happy to it... here is a video of that same 2032 cam on a fully bolt on l98
http://www.youtube.com/watch?v=Yja12X-pCsI
Reply 0
Oct 3, 2010 | 09:47 AM
I have it in my formula. Don't waste your time. Go bigger...
Reply 0
Oct 3, 2010 | 09:52 AM
i would agree with bullydawg... but you have a superram and trickflow heads... that 2032 cam way is way too small you for but its big enough for a stock tpi and stock heads...thats the biggest cam he can put in there without any headwork or computer work........ its just a noticeable difference in torque down low.... that was with my old engine.... but now i stepped up to the gm hotcam and im much happier with that... but you have to modify the heads and get a tune and all.... would not work well with a stock tpi... but a high flowing unit would compliment it nicely...
Reply 0
Oct 3, 2010 | 10:22 AM
I did not know that it was the biggest cam you could go with stock heads... how does it compare to the LT1 cam?
Reply 0
Oct 3, 2010 | 10:38 AM
its alot bigger than the lt1 cam... the l98 and lt1 are almost the same.. wouldnt bother swapping in a lt1 cam... but the stock heads have a max limit of 470-480 lift and the crane 2032 is pushing it as far as lift goes.... and since its under 220 duration its computer friendly... it made a difference for me because i had tpi and stock heads..... but with your superram and heads i would have put in a cam in the 224-230 duration area and mid 5xx lift range.....
Reply 0
Oct 3, 2010 | 03:19 PM
That cam is been around a long time and is a good upgrade to a standard TPI setup.
Reply 0
Oct 24, 2010 | 05:32 PM
i have 1.6 roller rockers would that make the lift too big for stock heads?
Reply 0
Oct 25, 2010 | 11:02 PM
I recently ask the same question on another forum. I expect someone who has this 2032 cam in their dyno sim to answer eventually.
How far are your overall specs from this link? http://www.popularhotrodding.com/eng..._manifold.html Mine are close or a bit better in CR with 2vrs.
447horses? a surprise to me but the cam is a notch or two up. I would be happy with 400 at the flywheel.
Reply 0
Oct 25, 2010 | 11:39 PM
first off yes that cam is too big with 1.6 rockers... stock 1.5 rockers are the limit without any head work... i had that cam in my bolt on l98... low and midrange power increased.. you will not be anywhere near 400 horsepower with that cam and tpi..
Reply 0
Oct 25, 2010 | 11:43 PM
Quote: i have 1.6 roller rockers would that make the lift too big for stock heads?
2032 Valve Lift with Factory Rocker Arm Ratio: 0.452 int./0.465 exh. lift
2032 Valve Lift with 1.6 Rocker Arm Ratio: 0.482 int./0.496 exh. lift
Per 88fastgta (above), the stock heads have a max limit of 470-480 lift. I've always heard this as well. Therefore, Yes - the lift would be too high with 1.6rr.
Hope this helps!
Reply 0
Oct 26, 2010 | 08:59 AM
I have the 2032 with 1.6RR's. On my stock heads. Works fine with the proper hardware.
Reply 0
Oct 26, 2010 | 02:21 PM
i'm using that cam in my 305 with 1.6 ratio rockers, i like it 380/420 to the wheels
Reply 0
Jan 2, 2012 | 12:11 AM
Quote: i'm using that cam in my 305 with 1.6 ratio rockers, i like it 380/420 to the wheels
to make those kind anumbers you have to have alot more then just the cam
Reply 0
Jan 2, 2012 | 09:55 AM
Quote: to make those kind anumbers you have to have alot more then just the cam
He also has a procharger
Reply 0
Jan 2, 2012 | 06:03 PM
Will the 2032 work with my tpi 305? Everyone who brings this cam up has a 350
Reply 0
Jan 2, 2012 | 08:12 PM
Quote: Will the 2032 work with my tpi 305? Everyone who brings this cam up has a 350
Yes, it will work great with 305 or 350. 86Z has it in his 305 and many others also do.
Reply 0
Jan 2, 2012 | 08:36 PM
Its probably a better 305 cam than a 350 cam. I like a little larger cams, and would add 5-6 degs to it for a 350 car but its a good cam for a stock headed car that you dont want to rebuilt the heads for higher lift cams.
Reply 0
Jan 3, 2012 | 03:31 PM
i did finally get a dyno run on my car after installing the cam in my 350 with a custom chip and a few other small mods it pulled 278hp 356tq @ wheels and does the quarter in the high 13s im very happy with it
Reply 0
Jan 3, 2012 | 03:37 PM
Was that with STock TPI or aftermarket TPI intakes? Thats really not bad at all with stock TPI! Aftermarket units I'd expect abit more power than that but really depends on the dyno. I'd expect stock cammed L98's to make 240-255whp depending with aftermarket TPI big tube setups. With mild cam, figure 10-20whp more, possibly more depending on the cam.
Reply 0
Jan 3, 2012 | 03:51 PM
stock tpi setup ported a liltle bit with a custom tuned chip for the cam plus 92 octane and bam 278 rwhp not bad at all. I will proberly make a bit more soon im redoing the ignition and the fuel pump when the warm comes back proberly get 10-15 more out of her hopefully
Reply 0
Jan 3, 2012 | 03:57 PM
Your original post said 255 / 350 i thought? So its 278? Thats MUCH better and along the lines of what I expected...actually abit more considering the stock base with alittle port work. very nice.
Now if you had 2800-3000 stall, full suspension and some drag wheels in cold NJ air down at MIR in November, you should beable to run 12.7-12.8's if the car isnt over 3500 lbs with you in it
Reply 0
Jan 3, 2012 | 04:05 PM
good numbers hope when i get to the track in the spring i can get in the 12's with the 2032 tpis intake, slp runners, msd distrib, ported plenum, and 3" magnaflow with hooker 2055's
Reply 0
Jan 3, 2012 | 04:09 PM
shes running solid mid to high 13s on 255 tires with fully stock suspension the trans is built but no stall. there is some spin with those tires i may need to break out the drag radials that might put it to the low 13s braking into the 12s
Reply 0
Jan 5, 2012 | 04:57 PM
hey guys here is a video on youtube of her at idle take a look
http://www.youtube.com/watch?v=layB7...eature=mh_lolz
Reply 0
Jan 6, 2012 | 10:05 AM
What other mods do you have? You have aftermarket heads ?
Reply 0
Jan 6, 2012 | 10:19 AM
i have used that cam about three years ago in my car it was a nice little cam... but shortly my car blew up on the dyno with all the upgrades... i found out later that the engine block was cracked....
here are my mods at the time of the video
5.7 350 factory l98 engine with 150,000 miles on it
Rebuilt l98 heads
Cranes 2032 cam 452/465 214/220 112lsa
Cranes matching springs
SA performance double timing chain
Cranes Adjustable fuel regulator
Flowmasters 80s series 3.5 inch catback
Catco High Flow converter
Custom 3 inch built Y-pipe
Heated O2 sensor
Hedman Longtube Street headers
Ported and Siamesed SLP runners
Ported and Siamesed Plenum
Ported Edelbrock High flow Intake
SVO 24lb Injectors
SLP cold air intake with K&N air filter
SLP airfoil
IAT relocated to SLP air box
160 thermostat
Throttlebody Bypass
EGR delete
Heater valve delete
Air/smog delete
LT1 Starter
Heavy duty flywheel
MSD 8.5 super conductor wires
Accel super coil
Performance radiator
Pro built 700r4
Transgo shift kit
Tranny cooler
2300 converter
High flow water Pump
http://www.youtube.com/watch?v=YmAOjTj03yU
Reply 0
Jan 6, 2012 | 10:24 AM
Quote: i have used that cam about three years ago in my car it was a nice little cam... but shortly my car blew up on the dyno with all the upgrades... i found out later that the engine block was cracked....
Rebuilt l98 heads
Heated O2 sensor
SVO 24lb Injectors
SLP airfoil
160 thermostat
Throttlebody Bypass
EGR delete
Heater valve delete
Air/smog delete
LT1 Starter
Heavy duty flywheel
Accel super coil
Pro built 700r4
Transgo shift kit
Tranny cooler
2300 converter
were you ever able to get a 1/4 time or dyno numbers b4 it blew up?
Reply 0
Jan 6, 2012 | 10:47 AM
no track numbers but i did get dyno numbers, then after a third shot on the dyno it blew up..... my dyno numbers were 213whp and 283wtq... i was super pissed by the numbers... but the engine was old and had over 150,000 miles and had numerous overheating problems in the past....found out that the blocked was cracked.... so that may be the reason to my low numbers..
Reply 0
Jan 6, 2012 | 03:57 PM
Quote: What other mods do you have? You have aftermarket heads ?
nope heads are stock just got rebuilt and a valve job. the block is 30d over with 10.5:1 comp ratio and the whole thing is internal balanced oh and everything emmisions got tossed
Reply 0
Nov 4, 2012 | 12:21 PM
I want to bring back this thread. I read somewhere you need an adjustable fuel regulator to have this cam. Also you need no headwork at all. Just install and go?
Reply 0
Nov 4, 2012 | 12:22 PM
that is true, plug and play. will need a tune
Reply 0
Nov 4, 2012 | 12:55 PM
Its been my experience that ,that cam averages about 35 flywheel, hp increase over the stock cam in a well tuned TPI
a very good return in increased power for the cost in a stock TPI.
Reply 0
Nov 4, 2012 | 05:29 PM
I used to run this cam also... Decent cam, just too mild for my build. Bumped up to the 268XFI... I have it in my storage still... Haven't gotten around to selling all my old parts.
Reply 0
Nov 4, 2012 | 05:32 PM
when you decide to sell the 2032 cam lmk bullydawg
Reply 0
Nov 4, 2012 | 08:15 PM
I'll be home on leave in Feb... PM me...
Reply 0
Nov 5, 2012 | 12:56 AM
ok pm sent
Reply 0
Nov 5, 2012 | 11:18 PM
my friend of mine says there is a gm cam. hot cam that he claims will give me 44 flywheel HP. and will play nice with my computer. what is the next cam slightly bigger then the crane 2032?
Reply 0
Mar 13, 2013 | 09:04 AM
Quote: I'll be home on leave in Feb... PM me...
Hey Bullydawg, ever sell that 2032?
Reply 0
Mar 13, 2013 | 02:11 PM
I completely forgot about digging out the cam. I just got back from leave, it's still sitting in my storage. I won't be back for a year, but next time I am home I will be out and going through my storage selling all my spare parts.
Reply 0
Mar 13, 2013 | 04:44 PM
Quote: Was that with STock TPI or aftermarket TPI intakes? Thats really not bad at all with stock TPI! Aftermarket units I'd expect abit more power than that but really depends on the dyno. I'd expect stock cammed L98's to make 240-255whp depending with aftermarket TPI big tube setups. With mild cam, figure 10-20whp more, possibly more depending on the cam.
Those numbers has been done but with just a 1 3/4in SLP and Dyno Don Headers with dual cats and 3in catback and gutted air box with K&N Filters and with all the emissions an A/C hooked up.
These cars runs in the low 13's @104-106mph
Reply 0
Mar 16, 2013 | 11:31 AM
  #42
Hope this helps!
Posted from Thirdgen.org App for Android
Reply 0
Mar 20, 2013 | 12:36 PM
  #43
I have that cam in my car. Good idea to change your springs also. And while your in there changer your valve seals as well. I did install a Holley AFPR, I like them the best.
I also jumped up to LT1 24# injectors. YES I had to have it all tuned. Still runs a little rich, but for a 305....I have a quick one that's for sure. And the 3.73's help out a little too haha!
Reply 0
Sep 4, 2021 | 12:54 AM
  #44
ahhh Really! How is that possible?
Reply 0
Sep 4, 2021 | 06:35 AM
  #45
Quote: ahhh Really! How is that possible?
Dang, digging up an 8 year old thread! 😂
As I recall, he was running a ProCharger to get those numbers.
Reply 1
Sep 4, 2021 | 03:42 PM
  #46
Ah, the old days. I bought that cam 20+ years ago, got around to installing it back in early '04. I'm probably one of the few still running an old CompuCam? I run it with old Edelbrock RPM heads, TES headers and RPM exhaust, old style Accel injectors, an air foil, a ported plenum and otherwise stock TPI choking the whole system. Low-mid powerband is impressive feeling.
Reply 0
Sep 4, 2021 | 03:43 PM
  #47
Still rocking that cam since 2014. Sounds great with the magnaflow exhaust
Reply 0
Oct 21, 2021 | 12:49 PM
  #48
i had a procharger D1SC pushing 14psi of boost... and some other mod's
i pulled all that crap and sold it in favor for a cammed 6.0 LQ9. best mod by far.
Reply 0
Subscribe
