E85 Injector size
Old Oct 2, 2010 | 11:28 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
E85 Injector size
Trying to find out what size injectors I need to order to run that beautiful corn fuel.
Engine specs:
355 4 bolt, 1 piece rear main
Dart Pro1 Platinum 200 cc, 64cc chamber heads
HSR Intake, Holly 58mm TB
Comp XFI292 Hyd Roller cam
http://www.summitracing.com/parts/CCA-08-468-8/
My spidey senses have told me somewhere close to 42 pounders, but I wanted to check with you guys.
Also, anyone got any recommendations as far as a tuning system. Everyone keeps leaning me to Megasquirt, but I gotta be honest, I've never messed with any of it yet. How simple is this to install?
Old Oct 3, 2010 | 12:03 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: E85 Injector size
I'm guessing you're shooting for around 500hp? That kind of power would want around 38-40lb injectors for gasoline, but E85 likes 30% more fuel so something more like 50lbs would be more appropriate.
Old Oct 3, 2010 | 11:24 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
To be honest, if it makes 400 to the tires, I'll be happy. Everyone I've talked to says I'm being a little conservative. Only dyno type simulator I've really plugged any numbers into is CamQuest6. Between 450-500 is what it's telling me.
Old Oct 3, 2010 | 07:26 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I've had a similar setup to that in my car once and it put down 405rwhp and ran mid 11's, so that's what I was going off of.
Old Oct 4, 2010 | 12:56 PM
grr's Avatar
grr
put in the 65# siemens injectors, Ive had them on 3 different cars and they idle better than the 42# lucas injectors, plus if you decide to boost later you will be able to squeeze a little boost out of them. Plus they are cheap on ls1tech since all the boosted guys are ditching them for the new 79-120lb high impendance setups
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
