Confused on TPI TPS voltage reading...
Old Oct 4, 2010 | 07:31 AM
ken0hki's Avatar
Car: 91 TA GTA, 88 Camaro Covnvertible
Engine: TA 350 Supercharged, Camaro 350
Transmission: TA 700R-4, Camaro T5
Axle/Gears: 3.23 Posi in both cars
Here is my delima. My book (Chilton's) says to measure between B and C (middle and bottom) wires. My other book (Haynes) says to measure between A and B. Using B and C, I get over 4 volts (middle and bottom). If I measure A and B (top and middle), then I get the correct voltage I am looking for at about 0.58 volts. I am also able to adjust it properly.
I have checked all over the net on reading the TPS voltage. Everyone seems to agree on 0.54 at idle. The problem I am having is WHERE to take the voltage from. Some people say take it from the top and middle wire. Other people say take it from the middle and bottom wire. Which book should I believe? Car is running and TPS seems to be working properly.
Old Oct 4, 2010 | 08:22 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Confused on TPI TPS voltage reading...
You should measure it from the top and bottom wires (A & B). It should be set at .54 - .60 volts.
Old Oct 4, 2010 | 08:34 AM
ken0hki's Avatar
You mean top and middle?
Old Oct 4, 2010 | 10:54 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yeah, sorry about the typo. Top and Middle.
Old May 26, 2014 | 11:18 AM
Garrettflores93's Avatar
So what is the best voltage for the tps to be set at i have a 88 camaro with a v6 2.8
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 21, 2015 07:20 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
