Help me beat my dad at the strip...
Old Oct 4, 2010 | 08:34 PM
smoor154's Avatar
I have a 87 iroc l98 5.7 all stock have exhaust on it.. My dad has a 75 camaro high lift cam 4:11 gear and other stuff he's pushing 350 hp and ran a 12.75 in the qtr mile back in 1982 I need the absolute cheapest way to make it a race no turbo or spay I'm pretty sure my car would be 15 in the qtr mile let me know I thought a cam and intake or maybe 383 kit and leave mostly everything else stock.. I want to run with him not blow him out let me know what u think
Stock 87 iroc 5.7 tuned port with 3:23 disc brake 10 bolt
Old Oct 4, 2010 | 08:54 PM
Drew's Avatar
Re: Help me beat my dad at the strip...
What's the budget? You say you've got exhaust, care to be more specific?
Old Oct 4, 2010 | 09:44 PM
ponykiller1187's Avatar
Car: 1987 camaro iroc z
Axle/Gears: stock
to get anywhere near the 12s your gonna have to spend a good amount of money personally your best bet is nitrous i mean a 12 second car on motor is better then a 12 second car on nitrous but its alot more money to do it that way. with a good set of gears, heads,cam, intake, headers,exhaust you should be able to be close
Old Oct 4, 2010 | 09:57 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
THE HEADS! THEY HAVE TO GO! the stock ones are junk, the heads are what the real bottleneck of the TPIs problem with power. Not only on a restricted intake. Get a nice hot cam, different heads, FULL msd system on the car, high flow base intake and runners, headers and any tune you can get. You should be close there. TPIs on a budget ive only seen run a best of 13.9s 13.8s. Gears wont help you much, keep it middle or low gears i wouldnt run anything above 3:73s, gears dont help much anyway since you gonna run out of breathe in 4 grand range anyway unless you get some serious head and intake work to reach over in the 5 grand area.
Old Oct 5, 2010 | 06:23 AM
smoor154's Avatar
Sorry on my exhaust stock manifolds back to a knock off flow master still has the cat on it I have no emissions to pass took off the smog pump and air I would like to stay tpi or at least stealth ram on the in take and I don't know what realistic on a budget anything over 1000$ won't work for a winter build but let me know I can start buying the parts I need and eventually build a motor to race him
Old Oct 5, 2010 | 12:15 PM
Drew's Avatar
Nitrous is the only way you'll come close to your goal for under $1000.
TPI is expensive and it's an obstacle. A stealth ram or carb would be a quick and dirty solution, but that's going to eat half your budget. If you're serious about your goal, you might be able to come up with a used carb/intake, get some headers, a cam, maybe a good torque converter, and some sticky tires. You'd probably still be short of your goal, but that's about as far as you're going to get for around $1000.
Old Oct 6, 2010 | 07:51 PM
smoor154's Avatar
Update... My dads car ran13.7 @ 101 mph not 12.7... I really like the Holley stealth ram maybe a cam and a trottle body... Any thoughts?
Old Oct 6, 2010 | 10:47 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
A set of Dyno Don's Headers, Magna Flow 3in Cat back system, 2800 stall converter, cut out the bottoms of the air filter box, change the spark plugs rotor cap and wires, change the oil to Royal Purple, run without air filters at the track only, borrow some slicks and take out all of the interior for less weight. Now you may have a chance to run 13.7- 13.5 @ 100mph.
Old Oct 6, 2010 | 11:13 PM
Drew's Avatar
13.7 should be easier to reach. In stock form a 87 L98 car should run somewhere around a 14.7. Keeping with the budget, a $800 set of headers, or a $600 intake isn't a great investment. Heads are out of the question too. A cam with stock heads means either machine work or a really small cam. I'd probably just leave the engine alone.
I'd be looking for a cheap pair of headers, a good torque converter, and some sticky tires. Make sure the engine is running as good as it can. Address any maintenance and tune up issues. But don't go crazy on expensive ignition parts. Stock parts are more then adequate. A few of the free mods wouldn't hurt, port the plenum and runners, bypass the throttle body coolant passage, bump the timing, open up the air box. Consider a lower temp fan switch to keep the temps down between runs. Clean all the junk out of the back, leave the spare at home, etc.
Old Oct 7, 2010 | 12:38 AM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
do a basic tune up on the engine make sure you can get the most out of it
do free mods : grind down the EGR walls behind the TB, TB bypass, gut the air boxs, shave the weight down where you can,
next i would get a AFPR and set it to 50lbs people claimed that its worth almost 10 hp, go to the bone yards and look for a AL drive shaft once again this is cheap mods
as for intake, its gonna get expensive. depending on your skills and your local machine shop you might be able to lt1 intake conversion. with those mods and luck with traction you might be able to pull this off
Old Oct 7, 2010 | 04:51 PM
Engine: 5.7 LS1
FULL MSD, Slicks, Intake, and you should make the goal
Old Oct 7, 2010 | 05:00 PM
VincentZ28's Avatar
Excuse me but a full exhaust system is the best investment for more hp without taking off the intake manifold.
Old Oct 7, 2010 | 05:43 PM
Drew's Avatar
I agree, headers are a great idea... But not the most expensive set on the market when the budget is limited. You're talking about a $800 set of headers, and $500 cat-back, plus other parts when he's saying his budget is $1000 to reach his goal. Exhaust alone isn't going to make a full second impact on ET's. Try reading the thread before you reply.
Old Oct 7, 2010 | 05:51 PM
VincentZ28's Avatar
A set of Dyno Don Headers cost about $600 and a Cat Back cost about $250-$300. Labor is about $100-$150. $50 bucks over the budget. Check it out!
Old Oct 7, 2010 | 06:16 PM
Drew's Avatar
DD headers.. $570 http://www.top-downsolutions.com/pro...roducts_id=170
Y-pipe for the headers... $230 http://www.top-downsolutions.com/pro...roducts_id=172
Magnaflow cat-back $465 http://www.summitracing.com/parts/MPE-16829/
None of that includes shipping... Want to borrow my calculator? Or explain where you're finding the same parts for less money?
Old Oct 7, 2010 | 08:01 PM
VincentZ28's Avatar
Ok but its is the best hp you will have and you will have a smooth exhaust sound.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Gunner242
Dec 25, 2015 04:49 PM
Thaney9
Oct 15, 2015 06:37 AM
Giocio
Oct 1, 2015 12:20 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
