Large Tube Runners
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Large Tube Runners
Is any one running a Large Tube Runner with Nitrous Port???
Re: Large Tube Runners
You might have better luck on the Power Adder forum...
https://www.thirdgen.org/forums/power-adder/
Someone used to sell a set of large tube runners with the bosses for fogger nozzles already welded in. I've even seen a complete NOS kit on Ebay that supposedly came with the runners. They're out there, just not extremely common.
Do we know who exactly used to sell these runners?
I haven't had much luck in the Power Adder Forum...
You might try Street and Performance too... They carry a ton of oddball EFI junk. If you can slog through their goofy PDF catalog you might find something, but you can bet it's overpriced.
Where are all the Nitrous TPI Setup's ???
In the past? Send some emails... Pick up your phone and make some calls... NOS, Arizona Speed & Marine, TPIS, Street & Performance, etc... Go get the scoop from the source.
Bump for the Direct Port LTR Setup...
Maybe I should change the title of this Thread....
Car: 87 Camaro IROC-Z 5.7 TPI
Engine: 350 aka 5.7L Tuned Port Injection
Transmission: 700-R4
Axle/Gears: 3.27 posi
im sure you could run nitrous on a first tpi setup. but you would need to fabricate runners or go the easy route with a nitrous plate. an ls1 plate would probably fit the first throttle body. if not one would be very cheap and easy to make.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You could get creative and have nozzle bungs welded into any set of runners. The photo in the swapper's guide looks like someone did just that with a set of LTRs from TPIS. Take a look at the things that 1989GTATransAm is doing. He's definitely not afraid to get creative.
Do you believe that welding the runners would be more effective than a plate?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
50-80 bucks a wet nozzle, 8 nozzles + all the lines and distribution blocks.... Thread Starter
Direct Port Nitrous users unite!!!
88SS6SPEED
Nov 11, 2015 07:05 AM
Chas91Z28
Oct 22, 2015 10:12 AM
toronto formula
Sep 10, 2015 07:31 AM
