Surges at stoplights, backfires on decel
Old Oct 12, 2010 | 12:35 PM
timonator's Avatar
My 91 z surges when I'm stopped and in gear at stoplights. It also backfires a little on decelleration. Anyone know what my problem is? I have an adjustable fuel pressure regulator and thought maybe it's not Adjusted properly. What do you think?
Old Oct 12, 2010 | 12:45 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Surges at stoplights, backfires on decel
Vacuum leak/IAC?
Old Oct 12, 2010 | 12:48 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Is fuel pressure 45-50 KOEO?
Old Oct 12, 2010 | 01:19 PM
timonator's Avatar
What's KOEO ? I thought the pressure was supposed to be 35-39.
Old Oct 12, 2010 | 01:36 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
koeo = key on, engine off
Old Oct 12, 2010 | 02:08 PM
timonator's Avatar
I'll check that when I get home, but I've never seen the pressure that high.
Old Oct 12, 2010 | 05:41 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Yeah, I beleive factory on the 91 TPI is 45-50psi with no vacuum at the diaphram. You set it by unplugging the vac line with engine at idle or just KOEO.
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
Racerx974
Sep 19, 2015 10:16 AM
banksGTA
Sep 13, 2015 11:56 AM
