TPI swap on 4.7 dodge
Old Oct 17, 2010 | 06:45 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Well I posted something simlar at dodge fourms and waiting an answer but I figure i'll ask here to.
Im highly curious if anyone knows if an lightly modded tuned port intake would swap fairly easily + an tune to an 4.7 magnum/powertech engine?
Say it will, would I need any other things to make the intake work properly on the engine?
I belive i'll be able to get an whole tpi setup for fairly cheap but what would the tune set me back?
I know it sounds stupid, but i should help us if we ever plan on towing, and the durango's already got decent torque, I just need the torque an bit lower in the rpm's and we would like an bit more of an slap in the face of pure torque
Thanks.
Old Oct 17, 2010 | 06:59 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: TPI swap on 4.7 dodge
unless you coompletely 100 percent redesign the intake and have a base custom built, no
Old Oct 17, 2010 | 07:10 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Thanks.
If you ever plan on towing... get a tow vehicle.
Old Oct 17, 2010 | 07:19 PM
Engine: 305TPI
5.9 durangos are rated for about 9000lbs towing, we dont need to tow 9k lbs I was just stating an fact.
yah, post #1,234!
Old Oct 17, 2010 | 08:55 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Yeah, my pickup (1/2 ton) is rated at like 11,000lbs, but towing 11,000# at only 10 mph SUCKS... Its really the suspension more than anything that can't take the load safely or comfortably. Ratings aren't for the real world.
Old Oct 17, 2010 | 09:01 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Why not just get a different truck?
Old Oct 17, 2010 | 11:00 PM
Engine: 305TPI
THE MAIN PURPOSE IS NOT TO BE ABLE TO TOW MORE #'S!
We dont want an difrent truck, all im asking is if the mentioned intake can be put on the mentioned engine!
Old Oct 17, 2010 | 11:03 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
see my post above......
you're talking about trying to put a chevy intake for a motor that was designed in the 50's onto a modern dodge motor
so unless you have the money/resources to have a base cast, no there is no possible way to do what you want to do
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
