What Horsepower am I looking at?
This winter I plan on doing a few bolts on's to my car.
I have recently done a TPI350 Swap
I have the Eldebrock Runners, and Manifold.
I have about 900 dallors i wanting to spend on my car.
I was thinking heads with 185cc intake flow, and 65cc combustion
Or would a good CAM, 1.6rr's, Harder Springs be better?
I have been doing alot of researching.
What kind of horsepower am I looking at now? rough estimate, i am assuming about 250, 260
With heads?
assuming 310
w/o heads but w/ cam, rr'ss, springs?
assumine 320
By spring I wanting at least 300rwhp.
With heads?
assuming 310
assumine 320
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: What Horsepower am I looking at?
With heads?
assuming 310
assumine 320
Need to do some more research,
Also you need to port your Eldebrock base & runners because there not much better then stock.
You need to post more info on the car,
With heads?
assuming 310
assumine 320
Information on the Car.
Its a 1987 Firebird TransAM
Bought with a TPI305.
I have put a GTA Dash inside it, GTA Bumper, and GTA Hood, as well as wheels.
I have done a TPI350 Swap keeping the T5 transmission for now.
As of now the engine is stock. It came out of a 1989 Corvette. However heads are not aluminum? Big heated discussion over that.
I have already purchased Eldebrock Runners, and Manifold
before install I am wanting to have the runners ported and the manifold ported, possibly siamesed. Also the stock plenum ported. I have painted the plenum painted orange, and sanded down the little flares in the middle so the aluminum shines(looks pretty dang sick)
Before the plenum there is a little V-Shaped item that screws into the Throttle Body.
And that is all i have done to the car as far as I know of.
And i really l ike these heads: Trick Flow Specialtiees TFS-30400014-M72 - Trick Flow Super 23 195 Cylinder Heads for Small Block Chevyhttp://www.summitracing.com/parts/TFS-30400014-M72/
dbrochard
Sep 25, 2015 04:56 PM
