TPI Throttle cable question...
Old Oct 23, 2010 | 12:14 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I'm running a set of ITB's and the throttle cable that came with this car has the wrong end on it, i'm looking for one that has the barrel style end on it. Anyone know if the TPI cable has this?
Here is the correct end..
and where it hooks up on the ITB throttle rail.
Thanks for any help.
Old Oct 23, 2010 | 05:28 PM
Engine: 450HP 355
Transmission: TH350
Re: TPI Throttle cable question...
lol, anyone? going to try and order this today, just need confirmation from a TPI owner.
Old Oct 23, 2010 | 06:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The 89+ cable has that end.
Old Oct 23, 2010 | 11:15 PM
Engine: 450HP 355
Transmission: TH350
Talk about a hard cable to find.. Hopefully Thirdgen ranch has one.
Old Oct 24, 2010 | 12:13 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Not all 89 s comes with this end I bought a throttle body off this guy and he had an 89 and the throttle body cable wasn't the same
Old Oct 24, 2010 | 01:19 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
im gonna post as well.... the 4th gen v6 cable(assuming the length is right) has that end on it and will fit in the firewall and attach to a third gen pedal as well
hope that helps
when i used the 3.4 intake on my car i had to find a cable with that end on it, luckily the 4th gen cable was an exact fit in a third gen
Old Oct 24, 2010 | 08:37 PM
Engine: 450HP 355
Transmission: TH350
hope that helps
Cool, there are a few 4th gens in the yard near me. That'll probably be the easiest thing to do.
Old Oct 24, 2010 | 08:44 PM
Pillsbry10's Avatar
no problem, glad i saw this thread before you went and blew a bunch of money on one lol
not sure if the v8 cars use the same connection
the only difference is how the cable hooks to the firewall but i put mine in and turned it and it has stayed in the firewall just fine
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
