heads swap with cam
Old Oct 29, 2010 | 12:55 AM
mlopezformula's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: 3.43
heads swap with cam
how far could I go with a pair of higher flowing heads with a cam, or in better word can I do that withought having issues with the tpi system? the car is a 305 lb9 tpi with an t5 transmission and a maf sensor. my bench mark car to beat is most likely a 05 mustang gt but it would be awesome to give a new wrx a run for its money. first I wanna get the power later I ll work with the traction and the drive train (diff and tranny) when I get more $$$
Old Oct 29, 2010 | 01:44 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: heads swap with cam
I am thinking about this camshaft for my LB9 TPI build: http://www.summitracing.com/parts/CCA-08-501-8/
As I see you have a 1989 Firebird with a roller block, so you could use this cam for example.
Old May 13, 2011 | 05:14 PM
Engine: LB9 305 tpi
Axle/Gears: 3.43
ooh cool thanks that answered the other question I had
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
