350TPI knock sensor on a 305TPI
Old Oct 29, 2010 | 11:30 AM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
I was wonderin if a 350 knock sensor on a 92 camaro 305TPI will that mess wit the timing and throw it off....i was told the car had a 350 and had to change the knock sensor cause it went bad then later on found out the car had a 305 instead...i left the 350 knock sensor in cause I cant get the other out...just wonderin if havin the wrong one in will mess wit the timin...thanxs for any help
Old Oct 29, 2010 | 11:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350TPI knock sensor on a 305TPI
It will be less sensitive.
Old Oct 29, 2010 | 11:50 AM
so it's ok just to leave it on then.....
Old Oct 29, 2010 | 11:56 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It'll run, but it may not be able to sense detonation and retard the timing.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
