The results are in.....
Old Nov 19, 2010 | 01:46 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
We flowed some intakes today....
First we flowed the TPIS Mini Ram
Just one port, but this thing is a sewer pipe.
It flowed "414 CFM" ....enough to support a 500 Cu.In. engine.
Then we flowed the FIRST Intake base
#4 intake port
It came in at "314 CFM" out of the box
We added the runner and it still flowed "297" CFM.
All this with no work done to them.
Old Nov 19, 2010 | 02:27 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: The results are in.....
He meant 297cfms. Not 197cfms. I just talked to him.
Old Nov 19, 2010 | 02:32 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Nice, what are your plans for the intakes?
Old Nov 19, 2010 | 02:43 PM
VincentZ28's Avatar
He was just giving out some need to know info.
Old Nov 19, 2010 | 03:47 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
MUST....RESIST....TPI....BUILD...AHHHHHHH
hmm...reconsideration begins but we'll see... :x
Old Nov 19, 2010 | 04:40 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Good Stuff! Thanks for posting up the #'s Don!
Out of curiosity was that the 1204 or 1205 mini ram?
Old Nov 19, 2010 | 05:28 PM
Dyno Don's Avatar
I forgot that....
The mini ram was a 1205 gasket.
The First was a 1204 gasket.
Old Nov 19, 2010 | 05:30 PM
vtwinsroc's Avatar
Car: 86 iroc,89iroc,98z28
Engine: 305,305,ls1
Transmission: 700r4/4l60e
Axle/Gears: 2.77/3.23
hey don what about Patriot Performance Part Number:2064-S are these worth the $
Old Nov 19, 2010 | 05:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Thats interesting numbers on the miniram... I seen results from one that was ported/cut/epoxy to match AFR 235 heads by Tony Mamo to flow only 400cfm. That was on corvette forum. Was this worked over? It sounds very high for a 1205 port
Old Nov 19, 2010 | 06:05 PM
Twin_Turbo's Avatar
http://forums.corvetteforum.com/c4-t...m-miniram.html
Old Nov 19, 2010 | 06:37 PM
thegooseman's Avatar
Car: 1992 RS
Well whatever it flows I know Im going to enjoy it on my new motor!
Old Nov 19, 2010 | 07:25 PM
Dyno Don's Avatar
It was ported in about one inch for the 1205.
By the way, the FIRST base was done on a good port this time, last time we checked a bad port. (301 CFM)
Old Nov 19, 2010 | 07:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah its a good intake setup you should enjoy it
Old Nov 19, 2010 | 08:49 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
That MiniRam had been on a mill. That thing was really opened up. This was over at Joe Shermans and he said that thing flowed more than anything he has ever had on his flow bench.
The results on the First with the runners have given me some pause. I thought the long runners would have knocked down the CFM more. I have been thinking about this all afternoon. I am going to build a set of runners that picks up the 2nd harmonic wave and see what happens. The CFM will be there and will be enough to fully support my AFR Comp heads. The TPI Research & Development continues.
I have to try and keep up with those pesky LSX guys in the neighborhood. Hahahaha.
Old Nov 19, 2010 | 09:05 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
THoguht the minis flowed about 275 out of th ebox.
Don I know you know your stuff but 400 cfm sounds extremely high but you were the guy on the bench....
Old Nov 19, 2010 | 10:44 PM
Car: 1989 GTA
Engine: 369 TPI
"THoguht the minis flowed about 275 out of th ebox."
The Mini Ram was not out of the box. The First intake was though. That Mini Ram had been on a mill and could have been larger than a 1206 gasket as far as I know. As Don said it looked as big as a sewer pipe.
Old Nov 19, 2010 | 11:40 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Where are you guys picking up the First base at? How much is that base going for? It sounds like the best TPI option.
Old Nov 20, 2010 | 12:29 AM
probably from www.firstfuelinjection.com I think there base only works with there whole setup though.
Old Nov 20, 2010 | 11:43 AM
Parrydise7's Avatar
Hey, Allen
When you get tired of your current engine, I've got first dibs, okay?
Old Nov 20, 2010 | 11:55 AM
Car: 1989 GTA
Engine: 369 TPI
The current engine is staying put. Maybe some fine tuning going on to extract a few more horsepower here and there. The intake and exhaust systems are fair game. Hahahaha.
Old Nov 20, 2010 | 12:27 PM
87350IROC's Avatar
Car: 87' IROC
How does this compare to what you guys are seeing with your TPI combos?
Old Nov 20, 2010 | 01:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
That should be interesting. You going to try this on the current motor or the 369" motor?
Old Nov 20, 2010 | 01:26 PM
Car: 1989 GTA
Engine: 369 TPI
Hi Orr
The Mini Ram is another persons project. I am seriously considering the long tube runners for the 369 inch motor and try to pick up the 2nd harmonic wave which I gather is much stronger than the 3rd. We are going on the dyno next Saturday so I can see what the current system is doing. That will give me something to compare with. I have had some interesting feedback on the other forum with private emails.
Old Nov 20, 2010 | 03:45 PM
Dyno Don's Avatar
When we weld up the roof and port the 3860 base (Edelbrock) we are seeing numbers around 310-330 CFM.
Old Nov 20, 2010 | 03:56 PM
87350IROC's Avatar
Car: 87' IROC
I am not totally familiar with what you guys are doing. When you say weld up the roof, the roof of what? The plenum? Also, what runners are you guys using to get those numbers?
Old Nov 20, 2010 | 04:35 PM
Dyno Don's Avatar
Check here:
https://www.thirdgen.org/forums/tpi/...-manifold.html
Old Nov 20, 2010 | 08:53 PM
Car: 1992 RS
Here are pics I took of a couple of the ports.
Attached Thumbnails The results are in.....-miniram-ports-1.jpg   The results are in.....-miniram-ports-2.jpg
Old Nov 26, 2010 | 08:49 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
you can just do that with a dremel right? or something special?
Old Nov 27, 2010 | 11:32 PM
Dyno Don's Avatar
You can but, that is a lot of work with a dremel.
Most of it was done with a domore high speed tool.
It has been done tho
check here: http://www.socaltpi.org/forum/viewtopic.php?f=6&t=17
Old Dec 7, 2010 | 03:52 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
sounds good. I do have a dremel and i was thinking of getting creative lol. thanks for the info link don
Falcon50
Aug 22, 2020 03:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Thornburg
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
