rough start
Old Nov 20, 2010 | 10:39 PM
protestthehero's Avatar
rough start
i have a 91 z28 and it has a rough start problem. when i crank the motor over, it cranks for a few seconds until the motor does fire but slowly. then after continuing cranking it will fire up.
Old Nov 20, 2010 | 10:45 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Re: rough start
Could be many things. Check your battery voltage first. So its a slow start from your description after its warmed up and then shut off does it fire right back up? Could be fuel pump, starter, battery, compression, plugs, wires, all sorts of things.
Old Nov 21, 2010 | 10:28 PM
Re: rough start
Sorry i wasn't entirely clear
I replaced nearly everything fuel related. (pump, filter, regulator, relay). i put in new plugs and wires. it cranks over fine, its just it seems to hesitate to fire. but when it has been running, it starts fine
Old Nov 21, 2010 | 10:31 PM
Re: rough start
and injectors too.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
