ZZ3 TPI?
Old Nov 21, 2010 | 11:59 AM
esbstuff's Avatar
Car: 1987 L98 Iroc Z
Transmission: Automatic
Axle/Gears: 3.42's
ZZ3 TPI?
Will the ZZ3 heads accept a 92 vintage TPI intake?
Basicly I have a complete TPI system that has been set up to run a 383 and found a smoking deal on a ZZ3 and wanted to know if it will all fit...
Old Nov 21, 2010 | 03:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ZZ3 TPI?
If the TPI base is from a Corvette it is a bolt on;
if from a F-Body you will need to slot the 4 center holes to accommodate the different angle used on the '87 + cast iron heads
ZZ3/ZZ4 alum heads are based on the 113 castings used in the '89+ Vette L98's
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
