Normal for spark advance to fluctuate at idle?
Old Nov 21, 2010 | 05:32 PM
QUICK305's Avatar
Normal for spark advance to fluctuate at idle on a speed density TPI?
Old Nov 21, 2010 | 05:39 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Re: Normal for spark advance to fluctuate at idle?
I believe so but how much is it fluctuating?
Old Nov 21, 2010 | 06:13 PM
QUICK305's Avatar
The changes are very rapid, but it appears the readings vary from 17-25. The numbers change so quickly I can't tell for certain what the exact high/low was.
Old Nov 21, 2010 | 06:38 PM
Car: Camaro RS
mine does the same. Why are you asking? does it run bad or somethin
Old Nov 21, 2010 | 06:39 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
NO... RUN !!!!!!!!
JK ya its normal
Red iroc-z 305
Sep 30, 2015 05:22 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
