TPI gasket
Old Nov 23, 2010 | 05:38 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
TPI gasket
Hey guys,
Stupid me bent my sunners trying to get them off and cant get them to line up perfectly with the plenum. Would it be ok to put some gasket maker like *the right stuff* between the runners and plenum?
-James
Old Nov 26, 2010 | 12:54 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: TPI gasket
Negative
Old Nov 26, 2010 | 02:42 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: TPI gasket
Ok thanks
Old Nov 26, 2010 | 03:33 PM
InjectorsPlus's Avatar
Former Sponsor
Re: TPI gasket
like he said, nope. I may have some around used if you need them. Let me know. I know they are in the shop SOMEWHERE just don't know where.
Old Nov 28, 2010 | 05:35 PM
norcalz28's Avatar
Re: TPI gasket
If the runners themselves are bent that's a problem. A thicker gasket may not seal it up perfectly. What year is your car? I have a nice set of 89 TPI runners for 50 bucks if you're interested, a couple small dents, but they are super straight. I'll throw in a new set of tpi gaskets for free if you buy the runners. Lemme know.
Old Nov 28, 2010 | 07:42 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: TPI gasket
Ill let you know. Right now I am just bending them back into shape and fixing all the dings. If it does not work I will get back to you. I have a 1990 iroc
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
Sanjay
Aug 12, 2015 03:41 PM
