heater, ac and egr cancellation problems
Old Nov 28, 2010 | 07:50 PM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
hello,
I am having trouble with the vacuum leaks on the engine, its a 305 tpia and I removed the heater, ac and the egr system, should I plug the HVAC tip, and remove the egr lines on the throttle body and the intake manifold? There is one long hose comes out from the throttle body, I do not know where it goes, but from the diagram I understand that it should go to canister, long stroy short, should I plug the tips that I removed the hoses from?
Thank you
db057
Sep 4, 2015 07:57 AM
dyeager535
Aug 28, 2015 08:10 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Fronzizzle
Aug 9, 2015 01:15 PM
