Mass Air Flow question need help
Old Dec 1, 2010 | 02:57 PM
ponykiller1187's Avatar
Car: 1987 camaro iroc z
Axle/Gears: stock
i have a 87 iroc camaro 350 and i finally get her running after a year and i timed it the other day which i think i did it wrong but it seems to run ok the only question is last night i drove it and it wouldnt run unless the mass air flow was disconnected like i unplugged it and it ran ok i dont know what that means. any help would be appreciated
Old Dec 1, 2010 | 07:56 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: Mass Air Flow question need help
If you haven't already done it, do a search on this site for mass air flow. Tons of posts and a lot of good troubleshooting tips. Kinda saves everybody rehashing the same topic. However, it sounds like your MAF is bad.
Old Dec 3, 2010 | 11:04 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
In case of a maf circuit failure the ecm uses a preset value to run the motor thats why it will run with the maf unplugged, but that doesn't always mean the maf is bad I would
replace the relays on the firewall near the brake booster first, there are three... maf power, maf burn off, and fuel pump relay. and go from there.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
