383 tpi Questions?
Old Dec 3, 2010 | 01:14 PM
Z28_KID_2005's Avatar
Car: 86 Z28
Engine: 305 tpi light mods
383 tpi Questions?
Ive done some reading in a couple books and here on the forum but still have a few questions regarding a couple things i havent seen covered and some conflicting information. I have a 1986 z28 that currently has a slightly modified 305 tpi in it. A while back i did a upper end rebuild switched from 184 valve set of heads to a 194 set i had off a old 350. I also put headers and a 3 inch exhaust on the car. Now while its parked for the winter ive put in a solid posi rear end and am switching from a stock 700r4 to a 4 speed manual trans. And now that i finally have a solid drive train going in the car im thinking about taking that old 350 block and making a 383 stroker to put under my tpi intake system. I know enough to know ill have to get a diffident set of injectors probably around 26 pounds and then get a new prom burned. And then probably fine tune it with an adjustable fuel pressure regulator. However what im not sure about is it really worth putting a 383 under a stock tpi intake. Will a stock tpi intake and runners let a 383 breath well enough to make it worth my time. Also id like some advice on what heads would be best to run on it.
Old Dec 3, 2010 | 01:37 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: 383 tpi Questions?
If your going to go through the trouble of making a 383 you probably want to use a better flowing intake on it, my choice would be a HSR and if your looking for a good head for the money Pro-filer's seem to make a nice one.
Old Dec 3, 2010 | 01:39 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
the stock intake has problems feeding a 350, you'll have to do some serious porting to use it on a 383. you might want to look at aftermarket products for a better alternative.
Old Dec 3, 2010 | 04:57 PM
Car: 86 Z28
Thanks for the advice so far. I did a little more research and spent some more time looking into products and am wondering what you guys would think about me using the stock intake plenum porting it and upgrading to a larger throttle body and then putting that on a Edelbrock high flow manifold with their high flow runners? Would the edelbrock runners and minfold be worth the money along with the larger throttle body?
Old Dec 3, 2010 | 05:18 PM
NT 89IROC-Z's Avatar
Car: 89 IROC-Z street car
Engine: 408 HSR Afr elim. Xfi 280
Transmission: PATC mega raptor 700r4 3500 stall
Axle/Gears: strange 12 bolt 4.11 gears
I would not use any type of TPI setup. I switched from a ported TPI plemun w/ twin 58mm TB to HSR and 1/8 mile E.T.'s went from 8.4 to 7.9. This was on a vortec headed .040 350 w/ the hot cam, 1.6 roller rockers hooker long tubes, 3000 rpm converter, 3.42 gears, and mt 26X10.5 et drags. With a TPI set-up you will never make power above 5200 rpm. Do not limit yourself. Do it right the first time. You can do hsr swap for less than the edlbrock tpi setup.
Old Dec 3, 2010 | 05:31 PM
Car: 86 Z28
Now the HSR that works with the same computer system and fuel rails correct that is just a new intake system? And i was looking at the holi stuff and i can get it for like 650 used probably.
Old Dec 3, 2010 | 05:46 PM
You can buy the hsr (holley stealthram) for vortec heads or non vortec heads. You have to buy the holley fuel rails and run new fuel lines from the new fuel rails back to where the factory rubber ones attach in the engine bay on the drivers side.The stock fuel rails will not bolt up. My old setup was with a stock prom and computer. I used to have a vortec hsr. I sold it and built a .040 sbc 400 with afr eleminator heads and used a non vortec hsr. The car runs 7.26 @ 95mph in the 1/8. Still with stock computer and prom. I might be able to get the vortec hsr back and sell it to you for cheap.
Old Dec 3, 2010 | 07:39 PM
Car: 86 Z28
Ya the more Research i do the more it seems like the HSR might be the way to go considering performance and price. I do have one concern with that and that is im runing a 86 tpi system so ill still be runing this threw a stock maf sensor which will probably be a restriction on the air intake. But if you have one to sell let me know id definitley be interested. Just out of curiosity what size injectors are you runing in the 400 small block. Ive seen most people runing 383 talking about either runing a 24 or 26 lb injector. Also what was yer thoughts on the afr heads compaired to the vortec ones. Ive heard good things about the vortec heads from some people i know and one here people talk about the afs like there worth their wight in gold.
Old Dec 3, 2010 | 08:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I do have one concern with that and that is ill still be runing this threw a stock maf sensor which will probably be a restriction on the air intake.
No it won't
Restriction is what the computer can read ; not the actual air flow through MAF sensor
Check out these times with a MAF
https://www.thirdgen.org/forums/post...41-post75.html
Old Dec 4, 2010 | 07:07 AM
InjectorsPlus's Avatar
Former Sponsor
How do you want the car to run, that's the first question.
Old Dec 4, 2010 | 10:55 AM
Car: 86 Z28
Well id like to maintain it as primarily a street car with the occasional trip to the strip and ideally id like to be pushing somewhere between 350 400 horse.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
