fuel mileage
Old Dec 21, 2010 | 07:38 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
fuel mileage
what kinda fuel economy could i expect from a 355 tpi with world sportsman heads 11.5 to 1 compression mid 500 lift cam with high 200 duration and with a set of 32lb injectors if it is tuned right. also has a 700r4 and 373 rear
Old Dec 21, 2010 | 08:52 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: fuel mileage
With a high duration cam running in OD you might be well below the efficient rpm for the camshaft. Really hurt gas mileage. I'd guess about 17 mpg on mostly highway miles. My mostly stock 350, 700R, 3;23 rear barely gets 20. (Not real satisfied with that either)
Old Dec 21, 2010 | 09:17 PM
Car: 89 iroc
Engine: 355tpi
Re: fuel mileage
even with the 32lb injectors and big heads id get over 15?
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
