Buying new MAF sensor, wich one to choose?
Old May 27, 2009 | 05:32 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
After a lot of research on my car with a steady SES light and rough idle I think my MAF sensor is broken. I have done all the diagnosis tests it is possible to do on the wiring harness and measuring is correct when it comes to the volts..
my main problem is a steady SES light..No trouble codes, but when I disconnect the MAF sensor the light goes off...So that means something with this sensor..And since the wiring harness is correct i was thinking of looking after a new one.
I have seen a lot of different MAF sensors and a lot of EXPENSIVE ones.
from 200$ to 800$....
Do you guys have any suggestions of what kind of sensor I should buy?
My engine is a stock 305TPI engine now but I am going to upgrade a little bit very soon. But first I want my TPI system to work perfectly..
Old May 28, 2009 | 12:06 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: Buying new MAF sensor, wich one to choose?
if you are dead set on buying a new one go to tpiparts and get one. do mess w/ the adjustable ones, waste of money. your going to pay throught the nose for a new one so be aware of that. dont waste your money on a cheap autozone or advanced auto one either.
Old May 28, 2009 | 07:04 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
OEM Bosch MAF sensors are the best best! (Anywhere from $379-400US, I think!)
Old May 28, 2009 | 09:51 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I have an OEM Bosch MAF for sale out of my 89 TA. It worked perfectly when removed to install my C950 setup...
Old May 30, 2009 | 05:57 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
I only know of three the original Bosch, Granatelli and a type know as a thick film transistor (TFT) which use to be made by a company called Wells. A company called BWD now manufactures these thick film transistor types. There may indeed be other types.
The Bosch type is know to have the least problems but may not flow as much air as the other two. The TFT type is known to set off the SES light. I do not know too much about the Granatelli type.
Do not remove the screens on the Bosch type especially on the air filter side as this will reduce the life of the sensor and these sensors are not cheap.
About a year ago my Bosch type failed prematurely because I remove the screens and I got a BWD TFT type. I had some SES light problems. A few months ago the TFT one failed and my local auto parts store replaced it for free with a Bosch type. Then a few weeks ago the Bosch one failed and the auto parts store gave me another free replacement one this time a BWD TFT type.
While I like using TPI Parts, Summit Racing, Hawks, etc with electronic parts that can fail I really compare the price at a local auto parts store. It would have been very difficult to keep sending these MAF’s back to these stores in the USA.
Old May 31, 2009 | 05:52 PM
Ok...I have been looking for a while on those remanufactured MAF sensors from different brands at Rockauto.
Are those sensors bad or what do you guys think?
Because I find the remanufactured one's for half of the price and sometimes under the halfprice of the NEW ones...
Another thing...If I choose that I have TPI system from year 88 the sensors are very EXPENSIVE...now I am talking about new maf sensors.
If I choose a MAF sensor for a 87 TPI camaro the sensor's have a different part number and are a lot cheaper. What is the difference on the years?
Isn't all the MAF sensor's from 85-89 on V8 (305 and 350) engines the same, on the TPI systems???..They looks like the same though..
Old Dec 19, 2010 | 06:41 PM
IROCKman's Avatar
do you still have that bosch maf sensor for sale if so how much are you asking ?
irockman
Old Dec 19, 2010 | 08:17 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Just a word about Advance Auto's MAF sensor, I have had one for years with no problems. There is no way i would pay $350-$500 for a MAF when you can get one for $130. All my other sensors and relays have come from Advance, with no problems either, Why pay more when you don't need too?
Old Dec 20, 2010 | 12:04 AM
IROCKman's Avatar
thanks red rock i do have a new micro-tech maf and i just sent it back as it is not working right it has a lifetime warranty but i have to send them in this is my second time i have a couple of bosch ones but neither one is working good the idle is high and also surges a little the wires are ok i am sure it is in the circut boards if i knew of a place to repair them i would send them in
IROCKMAN
Old Dec 21, 2010 | 06:36 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Are you certian you don't have a vacuum leak? Those symptoms sound awful familier to me.
Old Dec 21, 2010 | 10:14 PM
IROCKman's Avatar
I have replaced all the vac lines i have sprayed with starting fluid so far i have not found any leaks i am going to check egr solenoid next i am waiting for my new maf to come back to see if that will solve the problem
irockman
GTAman
Sep 21, 2015 09:57 AM
Logan Bryant
Aug 27, 2015 11:52 AM
trevor1010
Aug 26, 2015 02:41 PM
Bert87
Aug 23, 2015 03:50 PM
perZ
Aug 21, 2015 05:51 PM
