checking fuel injectors
Old Dec 20, 2010 | 01:55 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
i bought a 89 iroc about a month ago and it came with a set of 30lb injectors installed on it. My friend has a set of stock 22s i want to put in but they have been sitting for a while. what is the best way to check these without taking them to the local napa and spending 10 dollars a piece to check them.
Old Dec 20, 2010 | 06:30 PM
Car: 89 iroc
Engine: 355tpi
Re: checking fuel injectors
bump need answers soon plz
Old Dec 20, 2010 | 06:50 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Well tell us what you want checked, spray pattern? Ohms? You can check the later yourself with an ohm meter, they should read, if good, in the 16-12 range and all should be close to one another within about 1-2 points
Old Dec 20, 2010 | 07:29 PM
Car: 89 iroc
Engine: 355tpi
yea i just wanna make sure they will work when i put them in
Old Dec 21, 2010 | 06:43 AM
InjectorsPlus's Avatar
Former Sponsor
Injectors that have been sitting go stale. I wouldn't put them in without flowing them.
It's a lot of work to do something that has a high degree of possible failure.
If you want to send them in, we'll check them.
Old Dec 21, 2010 | 06:44 AM
Former Sponsor
Even if they ohm out, the pintles stick. Ohms won't tell the story, especially if only checked cold.
Old Dec 21, 2010 | 01:04 PM
Car: 89 iroc
Engine: 355tpi
how much would it cost for u guys to check them
Old Dec 21, 2010 | 01:38 PM
Car: 89 iroc
Engine: 355tpi
and by chance could anyone be able to tell me what kinda injectors r on my motor now on one side it has D1720BA and the other side is 24. the injectors r all black with a teal blue ring around the top
Old Dec 22, 2010 | 08:06 AM
southbay08's Avatar
They are 315cc / 30lb Lucas injectors.
Old Dec 22, 2010 | 09:26 AM
Car: 89 iroc
Engine: 355tpi
are these injectors any good
Old Dec 22, 2010 | 09:31 AM
southbay08's Avatar
We have always been partial to the bosch products because they seem to be
the most reliable product out there though Lucas and other companies put out
good products also.
Old Dec 22, 2010 | 09:35 AM
Car: 89 iroc
Engine: 355tpi
and does the computer have to b redone to use these injectors to their potential cause i got the car and it has these injectors and it still has a stock hypertech chip
Old Dec 22, 2010 | 09:44 AM
southbay08's Avatar
You would have to remove the chip and get a custom tune because it will not accomodate the amount of fuel for the 30lb injectors....they will be too big.
pimp2303
Jul 27, 2017 02:03 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
