Gas Tank
Old Dec 21, 2010 | 05:24 PM
jwoodworth90's Avatar
Gas Tank
I got a quick question. I have a 84 camaro rs that i will be putting an 85 TPI 305 motor in. My question is are the fuel tanks the same? I just want to be able to drop a new fuel sending unit and pump in the 84 tank. Does this sound right?
Old Dec 21, 2010 | 08:14 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Gas Tank
Everything will fit, but the tank from a fuel injected car has a pan on the inside of the tank to keep fuel around the fuel pump. A carb car (i'm guessing your 84 would be) doesn't have a pan in the tank. Might have fuel issues when running low on gas.
Old Dec 21, 2010 | 09:17 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Gas Tank
Not true! 89-92 has the pan in them. I had an 85 Z28 TPI an it didn't have it. Any tank will work fine. Just don't run it to low.
Old Dec 22, 2010 | 11:16 AM
Re: Gas Tank
Thank you, the 85 tank i have now leaks so i didn't want to have to buy a new one.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
