What's this and HVAC question
Old Dec 22, 2010 | 11:17 PM
jibz1985's Avatar
Car: 1987 IROC
Thanks in advance for the help. I have searched the forums and am still confused.
Pic #1- What is this and where does the rubber hose go to?
Pic #2- This line runs from the Vac ball and the CC servo and I know it is supposed to go to the HVAC line from the firewall. Don't I also need to T it off and send it to (pic #3)? If not, what goes to Pic #3?
Thanks again.
Old Dec 23, 2010 | 01:47 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What's this and HVAC question
1.Supplies vac to make power brakes work
Brake booster line goes to fitting at drv side rear of plenum .
( the steel pipe shown in pic below. Vette one shown; F-Body may be different )
Line from empty port on plenum ( pic 3 ) should run to a one way valve where it splits.
Rear port on valve goes inside to HVAC controls.
Side port connects to the hose you mention that runs to vac ball and CC
Old Dec 23, 2010 | 09:53 AM
jibz1985's Avatar
Car: 1987 IROC
Thanks vetteoz
Old Dec 23, 2010 | 10:31 AM
jibz1985's Avatar
Car: 1987 IROC
I have two hard plastic lines running from the same place the HVAC should. One is about 2-3 inches long and the other is about a foot. The one that is about a foot is what pic #2 was originally hooked to. Is that correct?
Old Dec 23, 2010 | 10:39 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The plastic lines went to the port that now has the rubber hose going to the reg on it .
Lines supplied vac to other items
Once again Vette TPI shown but F -Body TPI has similar setup
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
777Shock777
Oct 29, 2015 04:30 PM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
redmaroz
Aug 16, 2015 11:40 PM
