O2 sensor issues, phantom voltage?
Old Dec 23, 2010 | 03:51 PM
92TPI383's Avatar
Car: '91 Formula WS6, 2005 CTS-V
Engine: 4.8 & 80mm, stock LS6
Transmission: T56, T56
Axle/Gears: 3.23, 3.73
Hey all, I'm in the process of tuning my 383 TPI/T56 in my 91 Firebird. I am using the '730 ecm, DataMaster w/ $8D mask, and C.A.T.S. Tuner.
My issue is that my o2 Volts are stuck at 451mv. I have disconnected the o2 sensor, no change, back pinning the purple wire on the ECM, I get .3-.4v. Even as a last resort to isolate the circut, I clipped the wire to pull voltage off of it. Is my PCM smoked? I am usind a hypertech PROM that I burned a AXXD bin with AJUP VE and Main spark tables onto. Been searching on here for the past few hours with little luck. It is running damn good and will smoke the tires off in 2nd with 3.23's but I want to make sure it has a safe tune. THANKS
eightsixseven
Dec 16, 2024 01:50 PM
Cornholio7979
Sep 20, 2018 02:31 AM
mdtoren
Aug 23, 2015 12:52 PM
beast94
Aug 20, 2015 06:44 AM
mdtoren
Aug 16, 2015 05:45 PM
