Anyone using this combo, what kind of #'s
Old Dec 28, 2010 | 05:55 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
Hey, I'm goin' to be pullin' my motor out this winter and need some info.
Here's what's going in:
355 ci, Hooker shorties, Large tube runners, ported plenum, 52mm TB, LT4Hot cam, Edelbrock Etec 170 Alum. Heads, Scoggins/Dickey Vortec Intake, 1.6 Roller Rockers, 5 speed, Alum. Driveshaft, 3.73 Posi, Hurst short throw shifter, 26 lb. Ford Injectors, Double roller timing chain. What kind of HP numbers do you think I'm Looking at. Any change suggestions would be appreciated. thanks
Attached Thumbnails Anyone using this combo, what kind of #'s-100_3417.jpg   Anyone using this combo, what kind of #'s-100_4563.jpg   Anyone using this combo, what kind of #'s-100_3567.jpg
Old Dec 29, 2010 | 08:28 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: Anyone using this combo, what kind of #'s
your engine bay is amazing that is exactly what I want mine to look like like for the most part, your attiontion to detail with all the lines and hoses is amazing you will have some pms in the near future . sorry i couldnt help you with your hp quistion
Old Dec 29, 2010 | 09:13 PM
90t/aguy's Avatar
Car: 1990 Trans Am
gorgeous lookin car and engine bay
Old Dec 29, 2010 | 09:53 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Very nice. As to horsepower I will guess maybe 300rwhp. I am assuming the parts were just bolted together with no porting.
Old Dec 29, 2010 | 10:02 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
also he is using 170 cc heads
Old Dec 29, 2010 | 10:03 PM
iroc-z_23's Avatar
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
maybe 300 hp..id look into doing more with tpi intake for easier hp gains, not sure about the specs of a lt4 cam but if your looking for quarter mile times you might see mid to low 13's judging on the shifting
whats compression ratio?
my set up is
-355 brodix 180 cc aluminum heads w/ comp cam extreme energy 280 .520 lift, hooker shorty long tubes, 3500 stall stock bottom end 10.5 compression, 750 double pump rpm air gap. estimated 390-400 rwhp and im about 12.50s. good luck
Old Jan 11, 2011 | 08:46 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
I also could go with a Holley Stealth Ram with 30# injectors and a 58mm TB and ZZ4 113 Alum Heads. Undecided right now. Is there going to be an issue w/ hood clearance. What kind of numbers do you think this will give me with all the other things listed above?
Attached Thumbnails Anyone using this combo, what kind of #'s-b1b-wtqb2k-kgrhqr-gwe
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Gunner242
Dec 25, 2015 04:49 PM
hartsmike
Oct 2, 2015 07:11 AM
