Putting a 5.7 back together
Old Jan 3, 2011 | 12:29 AM
colohusker's Avatar
Okay, so picked up a 92 Z28 with a 5.7 in it and trying to get it running. The previous owner had started working on it, so have some questions on some things that aren't hooked up and hoping someone can help me sort things out.
In the following pictures, A and B are a component and a cut off plug that were laying in the engine bay. Where do they belong?
Plugs 1 and 2, I think I have 1 plugged in to the correct item, but where does plug 2 go to? Also have 2 hard vacuumn lines labelled 3 that need help with where they go.
Where does line 4 go to? It is just laying where I found it, but could go anywhere within reach.
On the canister, plug 5 on the top, where does it go to?
On the linkage in 6, are they switched on the bracket? They look like it would fit better if the throttle cable was inboard and the kick down was outboard.
Looks like some of the egr lines are missing on 8 and 9, any help on where those are supposed to go?
And last, on number 10, where does this plug go to? It looks like it should go somewhere on the AC compressor with the length, but I don't see a place.
Thanks for any help with any of these! If I can find a 5.7 around town I'll ask to look under the hood as well.
Attached Thumbnails Putting a 5.7 back together-plug-component-front.jpg   Putting a 5.7 back together-2-plugs-lines.jpg   Putting a 5.7 back together-canister.jpg
Old Jan 3, 2011 | 12:30 AM
colohusker's Avatar
Re: Putting a 5.7 back together
three other pictures
Attached Thumbnails Putting a 5.7 back together-ac-plug.jpg   Putting a 5.7 back together-egr-lines.jpg   Putting a 5.7 back together-linkage.jpg
Old Jan 3, 2011 | 12:31 AM
colohusker's Avatar
last picture
Old Jan 3, 2011 | 02:19 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
A- looks like the module that goes on the distributor. As far as the other stuff I haven't had a thirdgen in about 8 years so I don't remember.
Old Jan 3, 2011 | 02:29 PM
Twin_Turbo's Avatar
A is ignition module, it's part of the distributor.
B is part of the main power harness between the battery and the starter and alternator. Someone did some cutting there.
1 = MAP
2 = EGR control solenoid, should be on the same bracket as coil, missing completely. Vac line from it is hanging loose too
3 = vacuum one way valve, one goes to the vac reservoir and the other to the heater controls.
4 = vac control line for heater control valve.
5 goes to a semi plastic hard line that goes to the TB
6 is switched indeed, the other one is for the cruise servo it goes on the little stud on the front of the linkage
8 & 9 are for the heater. 8 goes to the heater control valve or if you don't have one the delete elbow on the line off the TB. 9 goes to the KC4 oil cooler if you have one, otherwise it goes to the rad on the side tank
10 goes into the back of the AC compressor
Old Jan 5, 2011 | 08:18 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I think 10 plugs into 8. It should be the pressure switch for the A/C.
It looks like 6 should be swapped (left to right).
camaro11j
Sep 19, 2018 08:49 AM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
cstrobel65
Aug 15, 2015 10:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
