E85 conversion on a 87 tpi
Old Jan 11, 2011 | 08:29 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
Ok guys hows it going, long time no see. i recently started putting together this new project on my 87 ta tpi. doing build up on the whole top end. discussions came up and i think i might want to try and convert to e85, plus a station about 5 mins from me carries e85 now. it works out good bc i had to put a hault on the project bc i bought a 2010 camaro. as im saving up again i want to sort out what i need to do. Here is my setup:
1. new alum cyl heads from afr running about 10.1-10.5:1 comp
2. big mouth manifold from tpis
3. big mouth runners from tpis
4. 52 mm throttle body from tpis
5. comp cams XR269HR/ 08-502-8
my stainless steel fuel lines already in place and summitracing tech line says they can run e85 as well as methanol and nitromethane.
I need new injectors bc of the upgrades so i figured i would probably get e85 compatible ones before i go out and get any. Any recommendations? what lb/hr?
and then the fuel pump, man i know this spot of the car like its the back of my hand. is there any e85 compatible pump that someone makes that is an electric in tank pump for our cars? and fuel filter as well?
thanks for your help or just shoot me a pm
Old Apr 28, 2011 | 09:21 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: E85 conversion on a 87 tpi
This is an interesting subject, i'd like no alot of this also.
Old Jun 18, 2011 | 03:40 PM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
any fuel pump will work. just make sure the tank is clean
Old Jun 18, 2011 | 04:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
takes nearly twice as much alcohol as gas for the same power, so id make sure you over size things a bit.
Though get ready for a price hike, Gov is dropping the paid support for alcohol, just has to pass the house n prez desk now. That 65cent kick back per gal they get will surley cost .75+ more on the price per gal of alcohol gas products.
Old Jun 19, 2011 | 07:44 AM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
Maybe they will realize corn based ethanol sucks for a fuel and stop using it.
Old Jul 15, 2013 | 04:57 PM
1991z28L98's Avatar
Car: 1991 z28
Engine: sbc383,chad speier222cc heads
Transmission: built 700r4 Yank 3600 stall
Axle/Gears: dana 44 3.73 gears
In some states you can get a waver for your emissions inspection because E-85 is considered an alternative fuel vehicle just looked it up for NC
lt1z350
Aug 28, 2015 05:57 AM
stalkier
Aug 21, 2015 01:54 AM
overdriv
Aug 20, 2015 03:52 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
