will it start...new motor build old tune
Old Jan 23, 2011 | 12:29 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I have a new motor going into my camaro right now and im just wondering what everyones opinion on this is. I had a 305 tpi with AS@M runners, edelbrock base, edelbrock headers stock injectors with a TPIS adjustable regulator and a LT4 cam. It was custom tuned by TPIS before i got it and ran very well. Now i have a new motor going in that is:
355
XFI 268 flat tappet cam (510 intake 515 exhaust)
Dart aluminum heads 64 cc chambers 200 cc runners
Speed pro forged flat top pistons with valve reliefs
AS@M runners
Edelbrock base
Edelbrock headers
24# injectors
My question is will it actually start and run with the tune i have now. I kno that i will need to retune for all the mods that are done to it but i want to kno if i can get it to run well enough for me to break in the flat tappet cam thats in my 355. What is everyones opinion of this?
Old Jan 23, 2011 | 05:22 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: will it start...new motor build old tune
Well, it will probably start and probably run. However, I wouldn't break it in with that tune. Your whole A/F mix is different with the new engine. Hopefully some of the gurus will weigh in on this one. I would hate to see you have a malfunction. Sounds like a pretty nice set up. I'm not qualified to advise you but am curious about others opinions.
Old Jan 23, 2011 | 05:29 PM
big_G's Avatar
Car: 2 '68 'Vettes, 1 '69 'Vette,
Engine: L79, Blown 383 and L-71 (427/435)
It should be fine. I assume you are still running a mass airflow meter system. If you have access to a real-time scanner, you can watch the O2 sensor values to be sure you aren't too lean.
Old Jan 23, 2011 | 05:36 PM
subroc's Avatar
Engine: 355 TPI
Still running a MAF. I will also have a wideband installed before the first start so i can figure out how lean or rich it is.
Old Jan 23, 2011 | 05:39 PM
big_G's Avatar
Excellent. I also assume you have added a good break-in oil additive like G.M. EOS or Comp cams lube?
Old Jan 23, 2011 | 05:48 PM
subroc's Avatar
Engine: 355 TPI
Going to run the comp cam lube and quaker state 30 which is what my machine shop recommended for breaking it in.
MustangBeater20
Oct 29, 2022 09:20 PM
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
355tpipickup
Aug 13, 2015 07:35 AM
Jake_92RS
Aug 11, 2015 10:39 AM
