Need help!! What timing advance to run???
Old Jan 31, 2011 | 12:00 AM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
i just found out that my 1990 305 tpi has 187 tbi heads on it i have base timing set at 8 degrees and i am getting a little spark knock and bad gas mileage will it run better if i set timing at tbi stock 0?? thanks for the help in advance
Old Jan 31, 2011 | 05:20 AM
CamaroIROC88350's Avatar
Re: Need help!! What timing advance to run???
I believe the factory set timing is 6 on most TPI cars. Try reverting to six and use a flasher to do it too.
Old Jan 31, 2011 | 11:24 AM
Car: 1990 Trans Am
but it has the tbi heads instead of the tpi heads so will it still run fine at 6 degrees?
Old Jan 31, 2011 | 11:29 AM
If you have a TPI intake why do you have a TBI set of heads if you don't mind me asking?
To answer your question on the TBI's I'm not certain.
Do a search on here for your answer. I'm sure you or I could find it if we wanted to.
Let me know what you find.
Old Jan 31, 2011 | 11:32 AM
Car: 1990 Trans Am
the engine was replaced in '98 with a rebuilt from advance auto. it has the l98 cam but the '187 swirl port heads
Old Jan 31, 2011 | 11:52 AM
Here you go, read through this thread about TBI related material. I'm not a TBI guy but I hope you can find what you need in this sticky.
https://www.thirdgen.org/forums/tbi/...check-out.html
Old Jan 31, 2011 | 11:54 AM
Car: 1990 Trans Am
i will read it thank you for the help
Here is another thread talking about swirl port 187 heads.
https://www.thirdgen.org/forums/tbi/...heads-why.html
I posted a 2nd link for you below. Sure, anytime.
Old Jan 31, 2011 | 11:57 AM
Based on some quick reading I see that the 187 head is the worst of all our heads for the SBC engine. If you could you should go to a better aluminum head such as L98 aluminum heads or the L98 iron heads if you're on a budget. But you could keep your current heads I suppose.
Old Jan 31, 2011 | 08:44 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The TBI heads require a very conservative timing curve in comparison to what is in your TPI EPROM.
You may have to run 0* initial or even a little less to prevent spark knock.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
