SLP runners and stock l98
Old Jan 31, 2011 | 11:58 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
I have a 89 formula 350 runs stong only 59000 miles and was wondering if i were to put a set of slp runners on would i notice any power difference and is it worth doing with no supporting mod's except a ait foil and kn thanks
Old Jan 31, 2011 | 12:10 PM
MustangTamer's Avatar
Car: 89 Formula Firebird
Transmission: 700 R4
Axle/Gears: 3:27
Re: SLP runners and stock l98
probably not unless they are siamesed, and then youd need to have the base and plenum ported to feel a seat of the pants difference. not worth 300 bucks just by themselves.
your best bet is to start with exhaust, headers catback etc.
good luck!
Old Jan 31, 2011 | 12:32 PM
hairysox33's Avatar
http://www.summitracing.com/parts/WND-7540/
Instead of buying the runners..... Think about this piece.... You of course have to buy fuel rails though...
Old Jan 31, 2011 | 02:36 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It should pick up alittle bit with siamesed runners if they are siamesed atleast 1.5" or so. It will shift the power band upwards alittle and flow just a tad more so more power can be made. Broaden the torque curve for more area under the operating range which usually means a quicker car. You may not feel the difference but the difference at the track will be seen.
These motors do run abit rich up top end, so leaning them out could help when combined with the runners.
Old Feb 3, 2011 | 09:05 AM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
My 91 GTA has the dealer installed SLP package on a stock L98. It included the intake runners, exhaust headers, exhaust system and ECM prom. Car pulls a little harder than a stock L98, but I don't have any numbers as I don't race this one at the track. Don't have any baseline numbers anyhow, as the car came that way delivered to the original owner.
Good luck!
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
