500 wrhp tpi
Old Feb 7, 2011 | 02:00 PM
  #151
InjectorsPlus's Avatar
Former Sponsor
Re: 500 wrhp tpi
Originally Posted by NufNuffZ28
You're very naive if you see it that way. You don't think a 360TPI/Superram would make 500rwhp on 150-200 shot?
Take the run I POSTED. 7.15@98(and that was no where near my best)
It calculates to this:
Your HP computed from your vehicle MPH is 537.52 flywheel HP and 483.77 rear wheel HP.
And no... grandma couldn't get in and out of my blue car. Too much cage... It won't be made to go get grocieries either. Not it's purpose.
Yeah, on a 200 shot, why not.
Old Feb 7, 2011 | 02:07 PM
  #152
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: 500 wrhp tpi
Well, if so.... your whole arguement is void. I NEVER stated it made 500rwhp NA, NEVER.
I'm not naive and understand much more than you obviously think.
And, Big-G, OK, and you can build a motor and put it in a turd and it will run, or a turbo on a turd and it will run, or a supercharger on a turd and it will run, or the list could go ON and ON.
Anyway, I'm done with this thread. Besides getting totally off track yall have not helped the OP with his goals at all. You have simply filled this thread with BS, put-downs and "hidden facts" that no one has seen yet.
ps, Big-G I do like your combo...
Old Feb 7, 2011 | 02:11 PM
  #153
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: 500 wrhp tpi
Explain your self better then. I'm obviously not the only one who missed you pointing out you used N2O. Being around the forums so long ( ) you should know how this stuff works. I don't think anyone is disputing forced induction is the way to go, in fact you've all but solidified it.
Sorry man it just smells funny so I'm not eating it. Just a little thing I do to keep from being bullshitted too much in life. Honestly you come in making claims like this you should be ready to back them up beforehand. That's just my way of thinking I guess.
Old Feb 7, 2011 | 02:34 PM
  #154
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 500 wrhp tpi
My appologies if I missed that, but i saw the post where you said 479 and 500 hp but did not mention rwhp or fwhp or with nitrous or not... i assumed flywheel at first, but when you stated rear wheel I was shocked...figured there had to be FI or N2O involved. I have no doubt those numbers were made tho with a 150-200 shot.
Still a good combo anyway you look at it. On motor its still a decent running setup. Probably bottom 12's which is quite common with TPI/heads/cam setups of those cubes in thirdgen fbods
Old Feb 7, 2011 | 02:37 PM
  #155
Former Sponsor
Re: 500 wrhp tpi
Exactly. I also thought he was saying NA. I think a lot of people reading this did.
330 HP on motor. nothing special.
Old Feb 7, 2011 | 02:50 PM
  #156
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 500 wrhp tpi
whp or crank? I think by the times its close to the low 300's whp mark...typical of those type heads/cam and TPI setups...more hp with the superam due to its higher flow and siamesed runners.
Old Feb 7, 2011 | 03:11 PM
  #157
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Re: 500 wrhp tpi
IIRC
LOW 300's rwhp TPI with over 450RWTQ torque
335 Superram
Best times were 7.66 NA
7.0 on n20
Old Feb 7, 2011 | 04:09 PM
  #158
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: 500 wrhp tpi
Realistically (to answer the OP's question or at least ponder on it) 500 RWHP looks like just a number, but that's a HUGE chunk of power. I've had a few friends that have made this kind of power, but N/A they're usually only sitting around 420-430RWHP in a real stout build at the most. You'll see more sometimes, but that's very rare. I know one friend of mine hit 505RWHP naturally aspirated, but that was in a 408 LSx. That's not your average build, and he had everything done to it that you could do. Lots of money invested. The other had 640RWHP with a turbo 4.6 4valve, and that car was just retarded as far as driving it around. Something like that is a DEATH MAGNET.
I would say 350RWHP-430RWHP (out of a smallblock N/A anyways) is a good goal to shoot for, but anything higher than that it starts getting fairly difficult and very costly at a very steep pace. Even easier to attain though if you've got a power-adder. Also take note that you can make 500RWHP all day and have it be completely worthless. That Cobra my friend sunk all that money into was FAR from friendly to drive.
Old Feb 7, 2011 | 04:51 PM
  #159
big_G's Avatar
Car: 2 '68 'Vettes, 1 '69 'Vette,
Engine: L79, Blown 383 and L-71 (427/435)
Re: 500 wrhp tpi
That's what I'm talking about. I can put around town and other than the whine, you would never think the engine had any *****. Blowers rock! My neighbor has an '04 Cobra putting down about 800 rwhp. Beat a turbo Hyabusa up on SH-130....Saw the far side of 200. Gets wheel-spin on D/R at 100. I won't ride with him...ha ha.
Old Feb 7, 2011 | 05:37 PM
  #160
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: 500 wrhp tpi
I've been in fast cars, but not THAT fast. I know you'll always get the itch, but some of these guys I know.. "squirrely" isn't the word to even describe the situation. I'm curious and afraid to get in those cars at the very same time.
Old Feb 7, 2011 | 05:45 PM
  #161
Former Sponsor
Re: 500 wrhp tpi
My tires (BFG G-FORC TA) break loose at 70, it is some scary stuff.
However, I like a little rumble.. But that's me. I'm not a fan of "tame" but then again, it's only a warm weather weekend car.
Old Feb 7, 2011 | 06:33 PM
  #162
big_G's Avatar
Re: 500 wrhp tpi
Oh, it's got a "little" rumble. 3 inch exhaust with Hooker Max-flow mufflers see to that, the cam is 244/248/114*...so it lopes a bit.
Old Feb 7, 2011 | 09:24 PM
  #163
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: 500 wrhp tpi
are you running a hydraulic or a solid? I bet that thing is beastly, especially with that 114*!
Old Feb 7, 2011 | 09:25 PM
  #164
big_G's Avatar
Re: 500 wrhp tpi
Solid roller.
Old Feb 7, 2011 | 11:49 PM
  #165
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: 500 wrhp tpi
I musta missed where the OP asked for info on a No2 or blower build.
Old Feb 8, 2011 | 12:05 AM
  #166
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 500 wrhp tpi
Post 1 and 22 state that he is looking to go turbo down the road and makes it clear he'd be happy with single turbo with 450-500whp. He just wanted to know if 500rwhp was possible on TPI but didnt state it had to be n/a. We all were quick to point out its highly improbable that it can be done without a power adder.
Details on other builds? maybe not...but any build with TPI making that power would be helpful here
Old Feb 8, 2011 | 12:28 AM
  #167
xch3no2's Avatar
Transmission: TH400
Re: 500 wrhp tpi
So I'ts gonna look like a TPI...'cept the turbo...No2 would be less obvious.
I think the thread is that of a circle master and he baited all of you in.
Old Feb 8, 2011 | 06:25 AM
  #168
Former Sponsor
Re: 500 wrhp tpi
Yeah, I agree you're probably right, but it was fun...
BlueIroc-Z
Jun 9, 2019 03:22 AM
stalkier
Dec 6, 2015 11:25 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
