Any rich folks? Dz302 w/TPI
Car: 89GTA, 62' GSXR1000-SS
Engine: 406-HSR
Transmission: Nocturnal
Remember the old 302 Z28? came factory with floating wrist pins on 11:1, shot peened rods, forged steel crank? 3.00 stroke? 290hp@6000? 7200RPM REDLINE! insane lift!! my favorite gm production small block.. i wanna see if anyone has seen a tpi converted 302 i think a 302 with larger bore .060 over maybe..
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Any rich folks? Dz302 w/TPI
Have you ever driven a DZ car, no torque ,nothing down low until the cam comes in
TPI intake idle - 4500
DZ cam 3K - 7k
Gives you a operating range of 1500 revs
Some insight
https://www.thirdgen.org/forums/tech...dz302-sbc.html
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
http://www.youtube.com/watch?v=16FRhHpqxLE
Sweet music!
Now....nostalgia aside no reason to put a motor that wants to wind up with an intake system that wont. Plus..shorter stroke so youll lose torque.
Tuned/tweaked right those motors could scream but believe me stock as they came the Z/28s were 14 and 15 sec dogs sorry to say. Build for torque, my friend
Sweet music!
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
someone over on the LS1tech board built a 302 out of an LS1 block and 4.8 crank.. hoping to making power to 8500... if i remember right.. all it did was push the power band up to 3500-7500.. making almost the same power the regular LS1's were making with bolt ons.. not really good for a street car... road racing maybe..
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I think a big port miniram would be the only thing to live on top of that.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Sounds like the match from hell.
DZ cam 3K - 7k
Some insight
DZ cam 3K - 7k
Some insight
This is actually an easy enough thing to do, 3.0 stroke medium journal crank from an L99 (4.3L V8) a 1 pc 350 block and the appropriate parts to go with it. You could even shove the crank in a Vortec 350 or LT1 and have some nice OEM heads to go on it. I'd probably do it with boost for mpg reasons though, and the conveniences of a roller block. It would make for a nice engine that combined milage and perfromance. I think that it was done in a mag for Drag Week or the likes actually.
Engine: 406-HSR
DZ cam 3K - 7k
Some insight
DZ cam 3K - 7k
Some insight
3.8TransAM
Oct 1, 2015 07:47 PM
3.8TransAM
Sep 27, 2015 08:37 PM
