no fire to fuel pump
Old Feb 9, 2011 | 05:36 PM
90blckiroc-z's Avatar
Car: 90 iroc-z
Engine: tpi 350
I have a 1990 iroc-z tpi 350 I replaced the fuel pump and tank but im not getting fire to the pump I checked all fuses and the relay but they checked ok is there anything else that could cause it not to come on
Old Feb 9, 2011 | 06:23 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
Transmission: Borg Warner T-5
Axle/Gears: Borg Warner 9 bolt - 3.70 posi
Re: no fire to fuel pump
the oil pressure sensor doubles as a fuel pump cut-off. if it leaks, as we all know they do, might be worth looking into. had it happen to me last year.
Old Feb 9, 2011 | 07:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
No it doesn't
Old Feb 9, 2011 | 07:03 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Maybe you have a bad connection at tank somewhere as a result of the pump swap?
Can you hear pump relay click when key 1st turned on?
Putting 12V to terminal G of the ALDL connector should make the pump run if the relay and pump fuse good
Old Feb 9, 2011 | 07:12 PM
Car: 90 iroc-z
Engine: tpi 350
I forgot to mention I replaced that sensor to thinking that would solve the problem
Old Feb 9, 2011 | 07:17 PM
Car: 90 iroc-z
Engine: tpi 350
I hear the relay when I turn the key on im thinking it is a bad connection at the tank to its a trans-am tank and the plug was different from mine and I took the end from mine and swapped them but the wires might be different on that tank I need to find out
Old Feb 9, 2011 | 07:18 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
Originally Posted by vetteoz
No it doesn't
actually it does, thought i'd negate the argument by including that it had happened to me, apparently it didn't work.
Old Feb 9, 2011 | 07:28 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
actually it does,
Actually it doesn't work as a cut off
When engine is running ;
fuel pump gets power from pump relay AND the Oil Pressure switch so if OP switch was to cut off from low oil pressure then fuel pump ( and engine ) would continue to run from power supplied through relay
Old Feb 9, 2011 | 07:30 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Would be a good starting point, should have mentioned that up front
Old Feb 9, 2011 | 07:35 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
almost correct....low oil pressure results in interrupted power to fuel pump, so the engine isn't destroyed by lack of oil. speaking from experience. A short in the switch resulted in loss of power to fuel pump, on the advise of a 25 year gm tech, replaced oil pressure sensor and power was restored to fuel pump. This is why I almost never post in these forums, someone else always wants to share their "knowledge"
Car: 90 iroc-z
Engine: tpi 350
I put the wires back on the same way I took them off the old plug it didnt look like it was any different the plug end was just different
Old Feb 9, 2011 | 07:41 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
still no power?
Old Feb 9, 2011 | 07:43 PM
Car: 90 iroc-z
Engine: tpi 350
nothing
Old Feb 9, 2011 | 09:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
almost correct....low oil pressure results in interrupted power to fuel pump, ..... speaking from experience. This is why I almost never post in these forums, someone else always wants to share their "knowledge"
So in your infinite wisdom , looking at the typical GM EFI pump wiring below ;
HOW does the OP switch shut off power to the pump when it is also getting power from the fuel pump relay which is energized by the ECM anytime the engine is running????
Old Feb 9, 2011 | 09:18 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Almost correct.
OP switch performs two functions ;
OP indicator to ECM during cranking only and power supply to fuel pump
If the OP switch does not close during cranking ( only ) then the ECM will not enable the injectors because it is not seeing the relay input signal from the OP switch ; consequently engine won't fire
Read
http://www.corvettebuyers.com/c4vettes/l98.htm
This is why I always post in these forums,
because someone else always wants to share their "knowledge" that is wrong or at best misguided
Old Feb 9, 2011 | 09:20 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Did you try 12V direct to the pump as I suggested above?
Old Feb 9, 2011 | 11:22 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
alright look, you can post all the diagrams you want, I don't care. it's not that important to me to prove this one way or another. I simply told of my personal experience, and a possible solution. congrats on turning this into a pissing contest. Again, just stating my experience, obviously schematic MUST disprove actual events. have a nice day d-bag.
Old Feb 10, 2011 | 12:26 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I don't care.. obviously schematic MUST disprove actual events. have a nice day d-bag.
Love how guys resort to name calling when on the losing end of a argument.
If you actually READ what I wrote above ,
you will see I agreed that OP switch was your problem but not for the reasons you state
OP switch on these systems is NOT a low oil pressure cut off switch
It is there as backup to keep the fuel pump running should the Pri power source aka the fuel pump relay go faulty and to allow you to start the engine ( with extra cranking to build oil pressure ) for same reason.
In your case , it is possible the faulty OP switch was not supplying the correct signal to the ECM while cranking ;hence no start
Old Feb 10, 2011 | 08:05 AM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
yes, that was my problem. i never said that it cut off due to low oil pressure, i said it cut off due to a fault in the switch. you just focused on one part of my statement to argue with.
Old Feb 10, 2011 | 04:56 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
you just focused on one part of my statement.
Because ,irrespective of your particular problem with the switch;
you have incorrectly maintained all along that the OP switch is a safety switch to shut the engine down at low oil pressure by killing the fuel pump.
Old Feb 10, 2011 | 06:34 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
I have maintained that because of the information provided me by multiple sources, most of whom have years of experience not only in the automotive industry, but specifically GM vehicles. I don't really care if you think i'm wrong, i'd rather help the person with the problem than sit and argue with you. Now if were finished, i'll get back to the thread on emissions equipment removal.
Old Aug 21, 2012 | 03:10 PM
Jerome113's Avatar
I know this is an old *** thread but I think both of you having your argument might of been wrong. I appreciate whoever posted the schematic because I have been looking for this for like 3 hours. So the only way I can see it working is the relay switching over once the key is put in the on position, this turns the pump on then after a duration of time the ecm cuts power to the relay switching the pump off. This primes the system and once the ecm sees the 12volt input from engine cranking, the oil pressure switch, then the ecm re energizes the relay keeping the pump on while driving. This is the only way I can see this schematic making since, btw Im assuming the timer is in the ecm if Im wrong let me know because I cannot find it anywhere else.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
