setting idle on tpi 305
Old Mar 31, 2012 | 10:58 AM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
ok when you are setting your idle do you need to leave paaper clip in our take it out before you start it. cause when i un plug my iac it will not start also when you put paper clip in the a b of the aldl is fan suppose to come on .
Old Mar 31, 2012 | 11:07 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: setting idle on tpi 305
You can temporarily turn up the idle screw to keep it running since you will be adjusting it anyway.
Old Aug 21, 2012 | 05:12 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
I need to do this relearn tomorrow night, it seems each guide i read through is a bit different.
so when you take the paper clip out and start the engine, you have to put it in drive and get a helper to set the idle with it in drive ?? just going off that attached guide for a corvette.
some other guides ive seen simply say unplug the IAC and plug it back in which sounds stupid.
specialized
Jun 18, 2022 09:26 AM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
