Do I have to port my plenum.
Old Feb 14, 2011 | 05:26 PM
89 formula nb's Avatar
Can anyone tell me if I have to port my plunem to upgrade to a 58mm throttle body
Old Feb 14, 2011 | 05:32 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: Do I have to port my plenum.
well you dont have to it will just turn into a 52 mm if you dont.
Yes if you have a 58mm tb and you want to use all 58mm of it you have to open it up other wise it will just be a waste as the stock openings are 52mm
Old Feb 14, 2011 | 05:39 PM
Thank you
Old Feb 14, 2011 | 06:55 PM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
Stock was 48mm. Also do a search, 58mm is overkill, I would'nt go over 52mm
Old Feb 14, 2011 | 08:24 PM
385IN2005's Avatar
Car: '97 GTP
Engine: 385 sbc, 3.8 Supercharged L67 V6
Yes, stock inlets on the TPI plenums are 48mm each.
Gotta port to at least 52mm to get the benefit of the larger bore throttle body.
Old Feb 14, 2011 | 10:19 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
my 91 plenum was closer to 52mm stock when i measure it?
Old Feb 14, 2011 | 10:53 PM
385IN2005's Avatar
Car: '97 GTP
You have to measure it at it's smallest point, which is on the inside edge of each inlet. The inlets are beveled from around 52mm on the outside edge to 48mm on the inside edge. It will only flow as much air as what the smallest point allows.
Old Feb 14, 2011 | 11:11 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
yeah that is prolly what happened
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
